Hey guys...I've been absent for a long time...what can I say...life happens!
So my wife and I just bought a 1430 sq.ft. house (one floor - open concept) that has electric heat but also was designed for a woodstove with a nice central brick hearth and masonry chimney. At some point this was converted to propane with a radiant style space heater. I think its a Cozy model, about 40,000b btu's. I've been trying to decide whether to keep the propane or install my woodstove. I'll try and lay out the details, because some of these details are important to note, and then hopefully some of you will have suggestions:
- I can buy the 2002 model PE Super 27 I've been using from our landlord for a whopping good deal - I used it for the last three years and it's amazing, mint shape and rated at 72,000 btu's
- I'd have to get a stainless steel liner installed in the chimney as the aluminum liner for the propane space heater won't suffice
- I have the option right now to get the 1000 gallon propane tank removed from the property by the current owners and therefore don't have to pay for the fuel as part of the house deal - it's about 1/3 full and we've calculated the cost to buy the existing fuel and actually it's close to the same cost as buying the used woodstove and getting a new liner installed
- all the propane lines and regulators would stay in the house and the space heater too, just the rental tank and fuel gets removed so the current owners get credit and close their account. I could always get a new rental tank down the road if we wanted to hook up the space heater somewhere else, like the crawlspace for example. or looking long term we could even do a propane furnace install in the crawlspace as it has about 5 feet of headroom...propane tankless hot water heater, kitchen stove, etc.,
- I have 10 face cords of seasoned wood ready for this winter, and a woodshed that I could disassemble and also take, these are bonuses but also significantly add to the hassle of moving
- the hearth base in the new house would need to be extended or have something put down in front of it to get the 18 inches needed in front of the Super 27 door - I'm about 5inches shy. this is not a huge deal in the long run as we want to replace the carpet with laminate wood and remove the floor hearth bricks to make a more clean and modern look. a simple tile hearth pad could be installed then but for the short term I'd have to screw cement board down in front of the semi circle brick or rip out some carpet and install some tiles right away.
So basically it comes down to cash flow right now, which we are tight on. The propane is turn key, clean and reliable. We walk in and it works, and offsets the cost of electric which is the whole point of this. However, the current owners don't know how it works in winter b/c they go to Florida. So, we have no idea how efficient it is or how much fuel it uses. Will I have to phone the supply company mid winter b/c the space heater is a hog on fuel??? On the other hand, the wood and wood shed are a pain to move, it's messy and will take some time to get everything installed to be up and running. But when it's done I know I have a reliable heat source and already know what the stove is capable of. I also have a saw, lots of wood gear and access to land to harvest from so still seems like the cheapest option of all, but the most work or course...especially now. People I've asked who don't burn wood think i'm nuts to consider moving my wood and the shed....you fellow wood burners will understand my dilemma more!
Questions welcome, comments appreciated. Keep in mind we are on a budget right now and every buck counts in the short term. We're expecting a baby later this fall too so that comes in to the equation as well. Here's a pic of the current set up with the propane space heater.
![Moving - need advice on wood vs propane Moving - need advice on wood vs propane](/talk/proxy.php?image=http%3A%2F%2Fi127.photobucket.com%2Falbums%2Fp142%2Fscott_killarney%2Fimage_zps42db1060.jpg&hash=ed1b8b1f01bad6759812500273637243)
