where our stove is now used to be where a giant smoke backthrowing brick fireplace, i tore that out last winter and now have the wood bruner pipe going up through the 16x20 hole left in the wall to the chimney from the brick fireplace. id imagine that heat is just pooring up that into the chimney.
so what i am wondering is what do i cover the hole with. i was thinking just a circular peice of 1/4 steel bolted to the concrete foundation block but then i thought maybe that wouldnt be insulated enough. i would seal it with concrete, but.....our chimney pipe doesnt run all the way up the chimney right now...just angles a foot up it. (i know its not code but money is tight and the chimney sweep(friend) said it would be safe until we had the money to line the whole thing.) meaning that when we have a our chimney cleaned the creosote will fall not just in the pipe but all the way to the bottom of the chimney in the basement. my mom originally just said shove some insulation in there but im about 99.99999999% sure insultation is quite flamable
any thought would be great...its gonna be cold soon so this will soon be a bigger problem.
thanks, ur all awesome
merry christmas
ccb
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
ccb
