I'm also very interested in this stove (really like the large view area and how it looks), but was wondering how large the firebox is. Does anyone know? For some reason that spec isn't listed in the brochure or on the VC website.
Fod01 said:1.5 cu'. Our third season with no complaints.
The new Merrimack is 3', but not a flush insert like the Montpelier.
I got a VC Montpelier installed back in Feb 2010 and have ahd so many problems with trying to keep it lit, smoke coming back in the room, dark brown staining on the glass every time, and at least an hour before the fan come on.
My dealer is coming out next week with authorization from VC to swap this one out with a new one. I will wait and see if that happens.
...and were assured that drafting would not be a problem despite the chimneys relatively low height.
...and are hoping it was a lemon
I was shocked that the 3 ventilation holes in the bottom were blocked and really not providing any source of air for combustion.
Any thoughts on the value of asking for a block off plate - what does it do?
Also, is an outside air kit a waste of money?
...we can still feel the smoke on the back of our throats in adjacent rooms.
jamiebg said:I just had a Montpelier insert installed, it looks great and works well. I've done 4 burn in fires as per the manual and I've done what i thing are adequate sized, hot fires - 4 18" split logs at one time - and the fans have yet to come on. The dealer, to whom i spoke yesterday and who was very cooperative, thinks I haven't had a hot enough fire yet to activate the fans and that he's NEVER heard of fans not working out of the factory (i've checked my outlets, power is fine). Is this really possible? I thought part of the idea behind an insert is to blow hot air provided by the fire into your house to heat it. Any insight or help would be appreciated. Thanks.
Question for the group - wood’s good fire gets hot fan is working etc. WHY: when the fan is turned up high doesn’t the fire get more air and burn hotter? That would seem to make sense if you wanted a higher burn rate. The intake holes on the front don’t allow for an increased intake based on fan blow rate - is there something misaligned as it was with myy fan unit?
Started a fire tonight and got dark smoke creeping back into the room again. Definitely a draft issue.
I had someone tell me to wrap the adaptor from liner to the stove with metal tape????
- the chimey backs onto an exterior wall, and goes through a bedroom upstairs. The stone chimney feels quite warm on that second floor and heats up that bedroom nicely. But should that be a concern? Could there be the dreaded secondary draft? I can even smell a touch of smoke there (there is an old stovepipe hole covered with a steel pie plate).
