Caw
Idk. I'm the same way and have pretty much only high quality tools, often multiples of things, but this just seems like a lot of work and money to measure firewood occasionally. To each their own though. Good luck!
indeed...I've certainly got this chart saved and have studied it beforeA moisture meter is just an ohm meter with an algorithm to compute the moisture content based on resistance. As you can see from the table, the resistance of wood is dependent on the species and gets more variable at lower moisture.
Totally, duplicates for sure in my workshopIdk. I'm the same way and have pretty much only high quality tools, often multiples of things, but this just seems like a lot of work and money to measure firewood occasionally. To each their own though. Good luck!
Yeah I mean I have a $600 chain saw but I don't take it out to cut a 1" branch when a $20 pruner will do the job. You know?Totally, duplicates for sure in my workshop
You are certainly inspiring me to get a General![]()
I use handsaw A LOT ...understoodYeah I mean I have a $600 chain saw but I don't take it out to cut a 1" branch when a $20 pruner will do the job. You know?
For me personally I have so much wood out back that if a certain stack wasn't up to snuff I'd just go check another stack and find something better. If it was all I had Id absolutely be burning it. You'll waste BTUs heating up all the water but won't ruin your stove or chimney burning mediocre wood as long as you add more air and keep it hot. It'll just not burn as long or he as good but it'll still keep you warm.Just a question...If you have wood and it's cold out and you check it with your moisture meter and it's not up to your standards what are you going to do? I can tell you that if I have wood and it's cold I'm going to burn it, I'd burn the moisture meter if it meant being warm.
I guess if you're buying wood each year to burn that year and you want to check the advertisers claim of seasoned it might be useful. If i have wood I've had split and stacked for a few years and it is burning season I'm burning it.
the reason is manufacturer guidelinesJust a question...If you have wood and it's cold out and you check it with your moisture meter and it's not up to your standards what are you going to do? I can tell you that if I have wood and it's cold I'm going to burn it, I'd burn the moisture meter if it meant being warm.
I too have a fair bit on my property and many optionsFor me personally I have so much wood out back that if a certain stack wasn't up to snuff I'd just go check another stack and find something better. If it was all I had Id absolutely be burning it. You'll waste BTUs heating up all the water but won't ruin your stove or chimney burning mediocre wood as long as you add more air and keep it hot. It'll just not burn as long or he as good but it'll still keep you warm.
I had a bunch of similar soaked punky splits this year too. Takes about 1 or 2 days to dry it out right next to the stove. Then burned very well.Everyone on here states to measure you wood at Room Temp. That is not always feasible. My Stihl Moisture meter says its operating range is 32 - 99 degrees F. One would think that you could build into the unit and adjustment value based on Temperature. Generally I add 1 % of moisture for each 20 degrees below 70. As far as stacks go, I have some wood in a stack that 90% is great (14 - 18%) and 10% is not (27 - 40%). The not so great is some punky Ash from Dead Standing that got wet from a leak in the top cover. That stuff is like a sponge. Burns great when it is dry. Basically if it seems heavy it gets put aside. That stack is over 100 ft from the house, I'm not about to drag a load of it to Warm up just to haul some of it back. I will take my chance on testing with a meter when the temp is 40 degrees and adding a percent or two to the reading.
for firewood, yes....hmmm, I guess you covered more than just firewood thoThe job of the moisture meter is to help you plan, check wood your scrounged or bought, monitor your drying methods, confirm that wet wood burns like crap and motivate one to stack more/ better wood for the future needs.
At work we joke they want us to run a Fiat like a Ferrari.Ha yeah my french grandma use to say "Champagne taste on a Beer budget." Probably applies to many here including me at times.
I've been saying this for 20+ yearsAt work we joke they want us to run a Fiat like a Ferrari.
just noting your sig.see my post #24 in this thread
I would like to know too..... Besides, making sure it's a nice clear section of wood (no knots) first of all, then make sure not to bend it when you insert it or pull it out I have no other guesses....A moisture meter is a needed tool but how does everyone keep from bending/breaking the tips off ?
