Moisture meter fun
fireview2788
972
SW Ohio
I started burning some hickory and oak that I got last year that was "seasoned" and found it to be dragging behind the stuff I was burning earlier this year. So I went to Lowe's and got a moisture meter. Fresh splits on a bunch of different original size splits (making bigger ones smaller) showed moisture to be 17-19%. There was a piece of cherry in there that read 14%. I split the splits smaller and they are burning much better so I am guessing that it's split size, so once again size does matter.
I checked the rest of my stuff just for fun. Ash that was dead standing but still had water come out of it when c/s/s last May read 19%. Hickory that was dead standing 14%, some various stuff in my stacks that had been in the round for years but split and stacked last summer show 18%, and finally the hickory c/s/s in December showed 30%.
I like my new toy.
fv
fireview2788 said:
I like my new toy.
I just purchased a "General Tool" MM from Lowes and I'm looking forward to playing with it. I'm not convinced, yet, that it's an accurate tool, but it will be fun. :coolsmile:
I don't have a MM but I want one. I doubt they are very accurate but the important thing is that they show a difference in moisture. I don't care if my 19% on my MM is the same as your 19% on yours. What I do care about is it showing a difference in moisture content between different splits at my house. 30% on fresh cut vs 10% on some seasoned stuff. Thats what I really care about.
My cheapy is more than accurate enough for me, I base this fact on my years of cutting wood, every piece of wood I have checked has made perfect sense to me, a few surprises here and there but nothing that led me to believe the MM was not reading correctly.
For me a moisture meter has been more than a just a fun tool. Since I pretty much only cut dead standing trees I plan on burning right away, or at least the same year, having and using a moisture meter has helped me immensely to figure out which trees will be ready to burn right away.
As for the accuracy, they are probably a lot more accurate in perecentage points that most stove thermometers are in degree points.
But then I guess stove thermometers can be fun tools too, even if they are not really as accurate as moisture meters.
