Hello as anyone witnessed a defrost cycle on the ondoor uint? I thought I noticed that the fan spins slowly on my 15k uint. My 12k single unit seems to be abnormally loud during defrost and the fan doesn't spin at all
This is a single 12k unit. I was concerned when I heard it go in defrost it sounded noisier than usual so I looked and noticed the compressor fan wasn't spinning I thought it was unusual
I don't know Mitsubishi specifically but most mini splits outdoor fan would be off during a defrost. The goal being to heat up the coil above ambient so running the fan would be counterproductive. The indoor fan will run just enough to keep it from icing up.
Yeah I was asking about the outdoor fan, does that make sense. I must have just caught the 15k unit right as it kicked into defrost because I did notice one day the fan was spinning slowly and water was draining
I remember when I was a kid 35 years ago our traditional split heat pump outdoor unit would go into a defrost and the fan would stop, the coils got hot(ter), then suddenly the fan would kick on and blow a huge plume of steam like a mushroom cloud.
I haven't seen it from mine. I have two systems, and while the larger of them is mounted on the far side of my barn (which I can never see from the house), the one for my small music studio is mounted right outside one of our back doors. I've never seen anything come out of it, but I do notice the fan is almost always turning, albeit usually too slowly to even hear. I only notice it because it's on a pad in a garden filled with ivy, and I can see the ivy leaves blowing in the light breeze it creates.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
