You do have some pretty big loads. I don't know what your pool load is when indoors but I can tell you it takes about 112,000 btus to raise my 15000 gallon inground outdoor pool 1 degree.
gg
gg
bigburner said:my indoor pool is 12,000 gals. 14 x30 I run it 4 hrs a nite which dumps in about 75k per hour. I will hover in the mid eighties, when it gets cooler I will add some time on the clock, I have in floor heat in the room also which we don't need for comfort, use when we want toasty floors.
goosegouner: If we use 240 lbs and just say 3600 lbs per cord of hard wood= a cord every 15 days to heat the pool alone.
goosegunner said:bigburner said:my indoor pool is 12,000 gals. 14 x30 I run it 4 hrs a nite which dumps in about 75k per hour. I will hover in the mid eighties, when it gets cooler I will add some time on the clock, I have in floor heat in the room also which we don't need for comfort, use when we want toasty floors.
So with that it would be 60-75lbs of dry wood in an efficient boiler. His pool is just under 4X the size. So a rough guess would be 240-300 lbs of wood per day.
I could be wrong but that is my quick math.
gg
Como said:Propane cost for me is twice and a bit more than those on NG.
It has been 3x.
So a major factor.
It has been 3x.
So a major factor.
bigburner said:Goosegunner - your math may be correct for bringing pool up to temp but your wood use assumption is way off. After the pool is at "set-point" The load is only the loss threw the building envelope, MUA etc.. Mine Example 4 hrs x 75,000 = 300,000 Btus per day, If my pool was 24,000 gals[twice as big] the load would not be any different [after reaching set-point] 300,000 per day. NOT 600,000 per day
bigburner said:you are missing my point, the load isn't the water after it's warm [set point]. If you put 15,000 gal pool in a building or a 50,000 gal pool in the same building and both were heated to a certain temp. The load to maintain the water temp is the same. There are some variables like surface tension, vapor pressure required MUA etc. But strip it down and it is the same amount of Btu's regardless of pool size. Look at this way - if I showed up at your house with 15,000 one gallon water bottles and it was all 72 F and you house was 72F after we carried them all in the house did we change the temp or the load? NO! Now my brother shows up with 35,000 more 72 F water bottles and we carry all those in, what happens to the load? Nothing. Its the delta T threw the envelope of the house, that is the load.
