I have nothing but good things to say about the mini-split AC. This one is by United Refrigeration. It is AC only no heat pump although my remote would be the same for both.
I installed this in my 'sun room' which is the SW side of the house. It think it is a 9k BTU unit which is able to cool both my sun room it is located and the adjacent dining room - about 700sq/ft.
My AC guy (friend of a friend) picked up the components and I installed and ran the electrical and lineset. When he arrived he made the final connections. I think I got everything at the time for under $1200 including install but that was about 6 years ago when I built my addition.
Gone are the days of lifting 1980's 200lb window AC units. Actually I think it started out as 120lb ac window ac units but as I aged so did the weight increase on the window units.
The quiet factor is what I enjoy - both inside and outside units are whisper quiet.
I've measured the temperature drop to be between 18-25 degrees as shot with the centech ir temp gun as the air exits the unit. I think thats right where it should be.
I used a 2" pvc pipe from the back of the indoor unit to protect the drainage line routed outside.
Had I been educated about these things I would have opted for one of the multi-zone units - where a single outdoor compressor can feed up to four indoor units - now thats slick.
Edit - oh and behind the tv and ac is the stairway to my upstairs - so that's where I have stored over 1ton of wood bricks, over 1 ton of pellets and my wifes xmas presents for the kids. It's a wok in progress...I want to build a swing out bookcase of sorts to house my hifi system and still allow access to my stash
(broken link removed to http://img.photobucket.com/albums/v206/jjs777_fzr/HearthdotCom/100_3412.jpg)
(broken link removed to http://img.photobucket.com/albums/v206/jjs777_fzr/HearthdotCom/100_3414.jpg)
(broken link removed to http://img.photobucket.com/albums/v206/jjs777_fzr/HearthdotCom/100_3413.jpg)
(broken link removed to http://img.photobucket.com/albums/v206/jjs777_fzr/HearthdotCom/100_3419.jpg)
(broken link removed to http://img.photobucket.com/albums/v206/jjs777_fzr/HearthdotCom/100_3420.jpg)
