glenng said:Good job SJ . I did some milling years ago with an 066 . Your pics make me eager to dustoff my Granberg and mill a spruce that I have into beams for a woodshed addition. Great job.
smokinjay said:Here is a take on the quality of the milling will see if we can correct this.
By BObl
R" means rough and "S" for smooth and "J" for jump or jaggies.
Actually now that I see it magnified that finish is very acceptable, especially for a first go, and I'd still accept that now as being OK for most of what I do. It also irrelevant if the lumber is going to be re-sawn or reprocessed. However, it is possible to get the finish smoother if you want to.
Here are a few tips.
1) The difference between R and S is usually the cutting speed. With a big saw it's tempting to push the saw a bit harder so that it cuts faster but then it bites more making a rougher surface, eventually it bogs down a little and so the operator backs off and this repeats over and over again. So maintaining a more constant pressure will assist in maintaining a more constant cutting speed which will maintain a smoother finish. In practice it also adds very little more time to the cutting speed.
2) Avoid rotating/twisting the mill back and forth as it moves down the log. This will reduce the slight rocking that inevitably happens because no mill is completely rigid or coplanar to the bar. I know this is inevitable to some extent when negotiating around lumps and bumps on the side of the log but moving the mill down the log at as close as possible to a constant angle will get rid of most of these jaggies.
3) Milling on top of an already rougher surface may produce an even rougher cut surface as the mill rides over the existing lumps and bumps. Using widely spaced rails on top of the log for every cut will reduce this effect and it also makes it possible to correct any twist that may have occurred from previous cuts.
Like I said your finish is already very good and the above are just suggestions.
Battenkiller said:smokinjay said:Here is a take on the quality of the milling will see if we can correct this.
By BObl
Good tips you got there.
As far as surface quality goes, most of the stuff will cup to at least some degree, even in a kiln. You end up having to run it through the planer no matter what you try to keep it flat. I just got done re-stacking a bunch of cherry and basswood that was cut on a Wood Miser. I carted the planer out there as well, since they all will need serious flattening, even though they were carefully stickered and clamped for two years now. Now's when I wish I had a real planer. The little Ridgid I have will do most of what I need it for, but when you have a lot to do it is S-L-O-W. Good thing about it is that mine came with a promotional lifetime warranty, so I'm gonna try to kill it and then get a new one.![]()
jman said:Another book you can check out on canoe building, go to www.gilgilpatrick.com Me and my wife are the ones making the canoe in his revised edition. Mr. Gilpatrick has many books on outdoor gear to furniture, we are in the process in making the furniture now at his shop.
smokinjay said:jman said:Another book you can check out on canoe building, go to www.gilgilpatrick.com Me and my wife are the ones making the canoe in his revised edition. Mr. Gilpatrick has many books on outdoor gear to furniture, we are in the process in making the furniture now at his shop.
Here is the one that I just won for .99cents
(broken link removed to http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320551982100&ssPageName=STRK:MEWNX:IT)
Battenkiller said:smokinjay said:jman said:Another book you can check out on canoe building, go to www.gilgilpatrick.com Me and my wife are the ones making the canoe in his revised edition. Mr. Gilpatrick has many books on outdoor gear to furniture, we are in the process in making the furniture now at his shop.
There ya go... the bible itself. ;-) Has several good plans in it as well, but you'll have to draw them out full size. The book explains how in great detail.
smokinjay said:Is there another book I should have along with this one?
Battenkiller said:Now's when I wish I had a real planer.
Jags said:Battenkiller said:Now's when I wish I had a real planer.
Hey BK - come on down. I got a Rockwell wedge bed planer that would just LOVE to sink its teeth into some of that.
smokinjay said:Jags said:Battenkiller said:Now's when I wish I had a real planer.
Yea jags bring that bad boy on down! How wide can you go?
Jags said:smokinjay said:Jags said:Battenkiller said:Now's when I wish I had a real planer.
It can go 18" wide but about 14" thick I believe. Feed a big piece of Oak through it and it looks like a snow blower :lol: 1/4" cuts at a time.
I wish it was as easy as just throwing it in - it weighs right at 1000 pounds.
peakbagger said:Acomment on the cedar strip canoe building. Both books are good guides but the gilpatrick book is the best for first timers. I have done two gilpatricks and two cedar strip kayaks. The one mistake I did with my original gipatrick was I went cheap with the varnish and regretted it. Buy some Epiphanes from Hamilton Marine. I used standard spar varnish on my original canoe and the UV rays "cooked" it rapidly. The strips were barely visible after several years. The boats with Epiphanes show barely any UV damage.
smokinjay said:...lol 18in. that is a big planner..
Jags said:smokinjay said:...lol 18in. that is a big planner..
Yea - it was built for industrial use, not homeowner. It was originally 220v 3 phase, but had been converted to 220 single phase by the previous owner. Its a pretty heavy hitter. I bet it will build up the chip pile faster than an 880 :lol:
smokinjay said:peakbagger said:Acomment on the cedar strip canoe building. Both books are good guides but the gilpatrick book is the best for first timers. I have done two gilpatricks and two cedar strip kayaks. The one mistake I did with my original gipatrick was I went cheap with the varnish and regretted it. Buy some Epiphanes from Hamilton Marine. I used standard spar varnish on my original canoe and the UV rays "cooked" it rapidly. The strips were barely visible after several years. The boats with Epiphanes show barely any UV damage.
got any pic's of them I love the wood canoe's and have only have seen one in person. Side note the kayak are loaded and ready for a 4 day trip starting friday A.M.
