According to the charts Osage only takes 12 months. A lot of drying your firewood will depend on split size, climate ( this fall around here it’s been in the 50’s & 60’s this & very dry this year) lots of extended drying time, how much sun & wind your stacks get. It’s doubtful you will season your oak in 1 year even if it was dead standing.What midwest hardwoods are able to be seasoned in 1 year? Does it take 2 yrs to season dead oak?
Dead standing Ash can be ready to burn as soon as it's cut/split some times, if not within one summer. Alternately you can speed up seasoning with a solar kiln.
In this part of the midwest, it's highly variable. Some summers seems like we only hit the high 90's a few times and have swamp like humidity or rain the whole summer through... you worry the wood is going to stay waterlogged forever. Other years, we'll have a few dozen days of 100+ with plenty of high 90's in the 'off' days, and no rain for months... that seems to season just about anything.
If you're worried, I'd probably stick with some of the lighter hardwoods mentioned. Though ash reportedly seasons pretty quick and is a bit heavier. I've been having pretty good luck scrounging craigslist... picked up a couple truckloads of osage / hedge earlier this year. Between that and various wood lot 'clean-up' projects, it's been quite a while since I've cut an actual standing/live tree for firewood. You might also consider those possibilities also, if seasoning time is expected to be short. Obviously, getting a couple years ahead is the best option!
No kiln, fairly small splits. I brought a couple pieces inside for a day, then split and checked outside. The meter is brand new, the popular General MMD4E, it calibrates ok. I'll recheck a few more splits of various sizes.So split up last January (~11 months dry time) on Red Oak. Are you drying it in a kiln? Are you checking the moisture content in the middle of a fresh split? It shouldn't be at 22-23% already. There's something fishy here.
In an EPA stove you can get decent heat but not real long burn times out of what I used to consider "crapwoods" - pine, Aspen, cottonwood, etc. and they season quick. PNW guys extoll the virtues of Douglas fir, but I doubt you have that in Indiana.
Ditto the ash. Will burn and give good heat even if not ideally seasoned, but under 20% is definitely better. Dead standing ash I find the branches are usually under 30% and often low 20's; but watch out for the trunks, they are often still 40%.
As previously stated, drying conditions and split size will be key.
Agree with my cheesehead bro Sawset about the box elder and soft maples in a year, but disagree on the hard maple - that's more like 2 years in my experience. Haven't had much experience with elm, but the chart I have says 15mo. Cherry should be good in a year, but doesn't burn well until under 20% in my experience.
I’m burning silver maple now that was all cut early in 2020, occasionally I run into a large split that could be more dry but most of it is burning very well for me. Some of this was split as late as May, but most of it earlier. As others have said, we had a very dry summer here so this could be why it dried out well. I’m sure another year would’ve made it burn a lot better but I am not having issues burning it now.
I have some large splits out of the same tree that I’m going to re-split because they are a little big and I’m curious what they will be, I’m sure above 20% because they are 8” across but I’m burning 4-6” splits without problems. This was a live tree that was a split trunk starting to get some rot if I remember right.
I’ve also had good luck with dead ash, but that’s getting harder for me to find. The ash I have on hand is getting saved for the colder months, I’ll throw some in tonight as it’ll be one of the colder nights we’ve had this year.
