Hi:
We have finally made a decision on a stove and (gulp) accepted the cost for the chimney we will need. We will be installing a hearthstone heriatage. We will have the rest of the installation contracted out but are planning on installing the hearthpad ourselves -- very soon.
I have reviewed the r value and size of hearth needed for our stove, bought our micore and scrounged a large slab of marble out of a family member's garage.
MY QUESTION IS .... that my husband and I are not sure (read debating over
) whether or not we need to also use durrock in addition to the micore for its stability and hardness so that the weight of the stove does not put too much pressure on the marble and cause it to crack. To add more detail, we know that our floors are not totally level in our nearly 150 year old house and the "subfloor" in our house is made up of 5" wide pine planks that are tongue and grooved together. Can we just use a leveling compound and skip the durrock or would others recommned the added strength and stability of the durrock?
Any other suggestions or recommendations on micore intstalltion? When I went to pick it up I was surprised at what at soft material it was.
Thanks very much!
) whether or not we need to also use durrock in addition to the micore for its stability and hardness so that the weight of the stove does not put too much pressure on the marble and cause it to crack. To add more detail, we know that our floors are not totally level in our nearly 150 year old house and the "subfloor" in our house is made up of 5" wide pine planks that are tongue and grooved together. Can we just use a leveling compound and skip the durrock or would others recommned the added strength and stability of the durrock? Any other suggestions or recommendations on micore intstalltion? When I went to pick it up I was surprised at what at soft material it was.
Thanks very much!
