Well I've started building a masonry heater. I have almost everything I need (maybe need some more refractory cement). I've complicated things for myself - the door is too big for the plans I have, 70% of the firebrick are sloped (think of a pyramid), and the 80 or so straight bricks are really really dense - 20 pounds per brick (6"x9"x3"). And all of the bricks are bigger than standard.
The brick (the dark ones are straights, lighter 1/4" sloped),
![MH Puzzling Together MH Puzzling Together](https://www.hearth.com/talk/data/attachments/182/182374-adcc5091adcd2300bb94edc091102890.jpg)
I rented a brick saw and split 80 firebricks and took the slope off 2 sides and one side of 80 more - so I've got a mixture of brick. I tried to cut the dense bricks and it was a problem. I will need to be patient with these. So I could use the door, I increased the plans a little bit, 4" wider & 2" deeper. Oddly the bigger bricks span the firebox floor in one direction without needing to be cut - I didn't plan it.
I've built the under the firebox area. And I have the refractory cement base to put on top of it. Problem - it weighs a lot. I stacked the base on some blocks and thought maybe I could just slide it over - no good. I am going to need help. It has to be placed straight down. Here it is. I threw a few bricks on top of the base to see what the firebox would look like and the dimensions of it (~26" wide).
![MH Puzzling Together MH Puzzling Together](https://www.hearth.com/talk/data/attachments/182/182375-321e538fbe2b5fa675bf4cba6bd9c667.jpg)
The below firebox area,
![MH Puzzling Together MH Puzzling Together](https://www.hearth.com/talk/data/attachments/182/182376-08b99718ab7ecb5b8c2c312327dec88e.jpg)
This heater is going to be massive for it's size. It is sitting on 21" of reinforced concrete. The amount of mass to move is striking.
