Good morning/afternoon gents,
Background:
We have a conventional fireplace, and we're in the process of upgrading to an insert. This is the insert we're trying to get installed, and the associated requirements: http://ironstrike.us.com/products/montlake-230
Minimum Fireplace Width 25"
Minimum Fireplace Height 21-1/2"
Minimum Fireplace Depth 15-1/2"
This is a link to an online photo album with pictures of what I'm working with: https://imgur.com/a/R2dK1
The existing dimensions are as follows:
To the top of the arch is 21.5"
The sides of the arch are 18"
Fireplace opening width is 40"
Fireplace back-wall depth is 27"
Fireplace depth is 21.5
Width and depth are good. Arch is a little too short to shoehorn the insert in as-is. One positive I believe I see is the bricks are unsupported on the backside.
So, what can we do here? Would the best approach be to cut a square notch out of the arch to give us clearance? I'm not super-concerned about butchering the brick. My logic is, to a different homebuyer, I doubt anyone would rip out a nice high-efficiency insert in favor of a wood-hungry. And even if they did, the hack-job behind the cover is now their problem. And no way will I ever revert myself.
ANYWAY, what I would really like to do is use this as an excuse to buy a Sawzall and do the job myself. Masonry blade, shop-vac, and just notch it. Can you offer reasons why this won't work or why I'm dumb for thinking it will?
I know a grinder is another way to go, but I'm not loving the idea of tenting off the work-space. But I will if absolutely required. (I'm suspecting the hammer and chisel method might come at the risk of causing the whole bricks to crack off.)
Thanks
Background:
![Method for opening up brick fireplace to accomodate an insert Method for opening up brick fireplace to accomodate an insert](https://www.hearth.com/talk/data/attachments/166/166017-b30b177976b6f6ada05e02c5a511b6ea.jpg)
![Method for opening up brick fireplace to accomodate an insert Method for opening up brick fireplace to accomodate an insert](https://www.hearth.com/talk/data/attachments/166/166018-3e4d3d4c82c29f1162fa59a716dfc0ed.jpg)
Thanks
