quick question guys, i brought a hearth and glass cleaner made by perkins and rutland vermont, says it cleans and conditions. anyway i didnt read the bottom says to not use on tempered fireglass doors. the merrimack isnt tempered glass correct?
Adios Pantalones said:Unless you're getting black gunk (which should be addressed with better wood/burning practices)- a paper towel with water, followed by a dry one will get the glass as clean as any cleaner. If you have black gunk- burn hotter and it will burn off.
Then there's no need to worry about the cleaner!
Woodstoves use ceramic- it's much more tolerant to heat shock because of low expansion.
