That would assume that I am over fired and/or the heat exchanger is dirty. (The latter is unlikely since the unit is brand new.)
How long have you been fired up now? A week? More? Have you looked at the HE tubes yet?
When I was running the Tundra furnace here, I found that cleaning my HE tubes weekly made a noticeable difference...and that is with burning 4-5 year CSS wood...buildup occurs much faster if burning marginal wood.
And I don't recall the exact number, but one of the manufacturers that participate on here said one time that xx thickness (it wasn't much) of buildup (soot/fly ash, or creosote if things aren't going well) is a pretty effective insulator...in terms of extracting maximum BTU's anyways...not so much if we are talking about house insulation
Also, while draft was set initially, draft is not a static setting. It changes all the time. If it didn't, then folks wouldn't have permanent gauges set up so they could make adjustments.
You are right, draft changes all the time...but the baro adjustment sets max draft, and shouldn't change, or at least not unless your chimney completely overwhelms it.
And I don't run a manometer full time so that I can make adjustments as needed...once its set, you shouldn't have to change it, unless you want to raise/lower it inside of the -0.04" to -0.06" window for some reason.
The reason I run one full time is just to check that everything is working properly after each time I load...make sure the baro door is not sticking a bit (it happens) or the chimney cap is getting plugged (have had that happen too...years ago) etc.
Bottom line is, the furnace is working better for you now, great. Most likely, based on what you have said, you are not over firing, hopefully not anyways. And as Laynes69 said, these things are pretty tough, so hopefully it would take a bit of abuse if it does turn out that your draft is too high now.
Edit: Never been compared with an RV'er before...I feel so...dirty now...
(JK)
Oh, and I never said anybody was going to "die a fiery death", just that you could damage your new machine if you aren't careful about setting chimney draft (blindly adjusting the baro)
Merry Christmas man!
