A masonry fireplace was partially deconstructed and turned into a masonry heater. Build along and emissions testing!
I thought that is what the ecco stove was?They didn't mention it in the video, but I imagine getting the stove to initially draft might be hard. I bet the owner has to light a small fire in those little cutouts to get the draft moving initially.
I'd never heard of a masonry
firebox reburning the smoke either.
I find masonry heaters fascinating as the idea of the thermal mass soaking up the heat and slowly radiating it out just seems so attractive. It's really too bad they can't make a modular version of this out of cast iron. Stack up cast slabs on top of each other to provide a burn chamber volume and side chambers for heat absorption. For a larger house you would want a larger firebox and more exhaust baffling. Stack on a few more slabs...
Go visit Europe and Asia, there are plenty of them over there - seem to get the job done. In fact, the Germans connect their types up such that they can 'think' knowing when to increase air - and they heat water, too. Creosote build up has never been a problem because the area above the firebox (the first bell?) gets so hot (1200-1800 F) so it acts just like a catalyst combustor - just bigger. It burns up everything, except on start up.I also wondered if there was some kind of flue bypass or another method for starting the draft. There was mention of a flue damper earlier in the video, but I didn't see anything about using it. I too find these masonry heaters quite fascinating, but I don't see very many that are the sole source of heat for a home. Perhaps there are some often glossed over flaws like excessive creosote formation in the "bells" or there just isn't enough mass to make it work, like most rocket mass heaters you see on youtube.
True, I've seen videos of nice masonry heaters in Europe and elsewhere in the world, but in the US many seem to fall short in one area or another. How is the top chamber able to reach such high temperatures? Is there an air inlet that allows preheated air to mix with the woodgas and burn? Without an actual combustor or some kind of preheated air inlet I'm not sure how the chamber would get hot enough to do anything other than collect creosote like a normal firebrick lined open fireplace. My main criticism is to the stove they built in the video. It's a far cry from "98% combustion efficiency" and 2+ g/hr is the proof. The 300 df flue temp seems pretty good for a high efficiency appliance, but the homeowner only able to bring down fuel oil consumption by 20% tells a different story. With a 60 lb firebox and assuming the fuel is only 20% water means that totally full that firebox could yield 334k btu over the length of the burn. Perhaps the home insulation is the issue and not the appliance.Go visit Europe and Asia, there are plenty of them over there - seem to get the job done. In fact, the Germans connect their types up such that they can 'think' knowing when to increase air - and they heat water, too. Creosote build up has never been a problem because the area above the firebox (the first bell?) gets so hot (1200-1800 F) so it acts just like a catalyst combustor - just bigger. It burns up everything, except on start up.
In North America, some companies are selling masonry heater/wood stove hybrids now (mostly made in Europe). But they haven't really caught on. I don't think burners know what they are and how to use them. Obviously, the future will head that direction at some point, especially as regs tighten up the amount of pollution allowed.
That is an assumption. We have had great discussions about masonry heaters over the years. I was lucky to experience a nice Tulikivi install at a friends up in Alaska and we have several Russian fireplaces locally. Search back on old threads.I never said they did. Yes, they have a long tradition of heating with mass heaters. It annoys me that this site doesn't promote the best burning technologies available to the public. You should be researching this stuff and pushing it to consumers - begreen, be green. Instead you just lump fireplaces and mass heaters together.
Some years there has been a lot of chat about them including a build of one taking place.I'll do some more research and start a new thread about masonry heater/wood stove hybrids instead of derailing this one. I'm not sure how new they are - but they are out there. I never hear anything here about them. They should be getting some attention.
