Is it possible to install a small hearthstone stove on the hearth in front of a prefab firebox, particularly a martin sb5400 or does it all need to be replaced? Firebox is surrounded by field stone chimney must be 25 ft tall. I'd say it's at least 10 inches in diameter inside. If it is possible to install a liner and use a tee to clean out and bump stove out onto hearth would it be better to use rigid liner pipe like duraliner or a flexible liner with insulation or a class a chimney inside of the current one? Sorry for such run on sentences.. thank you in advance. First time poster
![[Hearth.com] Martin sb5400 prefab wanting to install hearthstone on hearth. Need help! [Hearth.com] Martin sb5400 prefab wanting to install hearthstone on hearth. Need help!](https://www.hearth.com/talk/data/attachments/316/316936-671396c0f48ea680cdb5103c4332c2a0.jpg?hash=5BA0j9sbb5)
![[Hearth.com] Martin sb5400 prefab wanting to install hearthstone on hearth. Need help! [Hearth.com] Martin sb5400 prefab wanting to install hearthstone on hearth. Need help!](https://www.hearth.com/talk/data/attachments/316/316935-80e53bfc96e63163999f508c6cf84911.jpg?hash=1p3cNuuMLk)
