LLigetfa, I'm curious as to how you measure your cuts?LLigetfa said:I used a yellow lumber crayon to mark one time but then it broke in two so now I mostly just use the nose of my bar. Been known to use a hatchet too on rare occasion.
Ed
mayhem said:Way too much thought and effort going into this in my opinion.
Just use a pair of these. Couple cuts to get used to it and you'll be within a half inch of the desired length every time.
firefighterjake said:What if you have brown eyes?![]()
And what if the person who originally owned these eyes wants them back?![]()
PapaDave said:I like the gps idea,.....as long as it wouldn't constantly be telling me to "turn right".
darkbyrd said:CaddyUser said:
That looks slick. PVC and chalk-line chalk?
ETA: I'm a burning chunk! Unlike the disastrous top-down fire I just started, that's more like a smoldering mass right now.
You got it, PVC and Chalk-line chalk.....
bogydave said:My avatar has the jig I use.
easy on & off.
can mount it to a small saw & mark then grab good saw & cut.
After limbing, I put it on & get very close to the same length on all rounds.
here is the post & a video of it in action.
https://www.hearth.com/talk/threads/51317/
greythorn3 said:ya i love to cut the right lengths, seems my dang saw wants to cut a crescent insteal of a straight line anymore, i dont know what the deal is with it.
roundoak16 said:bogydave said:My avatar has the jig I use.
easy on & off.
BD's length gage has gotten a lot of criticism on some threads, but I like it and intend to make my own. Thanks for sharing BD.
If you cut your own wood, think about it:
Why cut a buck length more than once? Do you really love the 130 db output of your saw, frustration, wasting wood, gas, time, etc.?
Why cut a length shorter than optimal for your stove?
Either of the above wastes wood. Short cuts = more cuts per log, long cuts eventually = more cuts per log. Cuts = waste unless you're collecting and burning the saw dust. Anyone doing that? If so, your first name might (unofficially) be "Anal".
Only one short per log, at most, to deal with.
Beautiful stacks.
Less frustration.
No time-wasting "saw bar" or "two pinkie to thumb spans" measuring or log marking.
Not all eyeballs are properly calibrated.
Do you ever intentionally let gas or diesel spill on the ground when you're filling up your vehicle, tractor or gas can? NO? Then why cut twice (long cuts), or make more cuts than needed (short cuts). The result is the same.
I know some of this is picking nits for bucking up a log or a few. But added up over a lifetime, or the lifetime of a stove or your wood-cutting years, it would prove to be significant in comparison to the investment in the gage and time spent installing and removing it.
My $.02 worth.
I have certainly given that consideration. The problem with a single light source is that it would not be parallel to the bar, so the angle of the saw would affect the measurement. To overcome that, I would use two points of light that converge into one at the point that the bar is roughly perpendicular to the wood.barkeatr said:i got thinking that you could mount a laser marker pen at an angle on the saw...
barkeatr already stated that the laser pointer was not for "exact laser like measurements" so I fail to see why you had to go there.firefighterjake said:Bucking up wood to become stove chow isn't exactly rocket science requiring exact laser like measurements . . .
....regarding the light being parallel to bar, I was thinking it would not be parralel. i thought you could mount the laser at an angle to compensate..but now that i think about it the diameter of the log would change where the laser hit it, making the idea unworkable.CTYank said:greythorn3 said:ya i love to cut the right lengths, seems my dang saw wants to cut a crescent insteal of a straight line anymore, i dont know what the deal is with it.
Uneven height of bar rails, almost certainly. Likely caused by dull cutters on one side of chain. Doesn't take long to check & rectify all.
(Whenever you see dust coming off the saw, it is assuredly dull enough to require filing NOW.)
If the problem goes away when you flip the bar, you've found it.
