Magnetic thermometer proper location and Max temp for Jotul F118
Soup
62
Where it gets cold
Hi,
Getting close to firing up the stove...... I picked up a
magnetic thermometer...... Where should I place it....
and what would be the max temperature for the stove....
Thanks, Soup
Put it toward the back about 6" in front of the flue exit. A thermometer measuring the flue temp is also very helpful.
Will Do!
The Flue temp....... where would placement be.....
I will have a damper maybe like 20 inches up from the 90 that will be on the flue collar(rear exit setup)
A few inches above the damper. Is this single or double wall stove pipe?
Thanks!...
I will get one above the damper as well..... yeah, single wall pipe......(good that you asked..)
And I was going to put in double.... just couldn't(accessibility and cost--- made shielding instead)
So we seem to run the F118 at about 400F....(when we can get it up there -- that is the goal)
... what are we seeking to achieve (////how to/// accomplish) with use the damper
with respect to the upper thermometer on stove pipe's temp..
****I am thinking))) Damper's use is to reduce temp above damper????
and to what percentage Would be my question...
(if this is something that one can manage with a damper??? IE:Dampening)
Thanks, Soup
