Is that 2200 sq. ft. including the basement footage? The formula that the county auditor uses to figure sq ftg. may or may not have included your basement, depending on how "finished" the basement is (was)
If you have 2200 ft. ground floor, plus 2200 basement, then your stove is heating like a boss, just too small.
I hate to make assumptions, then get bit in the rear when it is realized, oops, didn't cover the basics.
If the upstairs and down are 4 degrees apart, sounds like you are getting the heat that you have distributed pretty well. I would think the heat loss to the duct work would be minimal once it warms up, unless it runs through uninsulated spaces.
Also, you said you can't install a wood furnace due to no chimney. Is it possible to put a wood furnace in the living space (where you could put a chimney) if you used one of the several that have glass doors. Treat it like a wood stove, part of the deco. The PSG Caddy and the Drolet Tundra/Heatmax (there are others too) look good enough to not have to be tucked into the mechanicals room. You could maybe add some minimal stand alone duct work to move the heat upstairs, again just treat the duct work as part of the view, just like some offices and restaurants do. Just throwin out ideas here...
