Maybe my father was right that I had to take the whole right side of the stove off, but that's not an easy task either unless they make long skinny wrenches.
I can't remember how long I've had the stove, this is my second new blower, it does force a lot more air and is a bit noisier, I would rather have heat so the noise doesn't bother me. I'm all about cleaning but I'm afraid I'll break something when I take it apart. How can I clean the fan when I can't even get it out . I'm sorry I'm just so discouraged
I have the cast insert, and the sides are very easy to remove, but I need to remove the hopper lid first, then just "lift" the sides up and to the side. They just hang on the sheet metal of the stove by 4 hooks that go into slots. Not sure how similar the FS is, but maybe start with removing the top and see if you can lift the cast sides off?
Did I hear my name????? Lol
Easy as pie to remove the convection blower.
Top of Stove....
Open up small Fill door and remove the two Hinge bolts (Mine are chrome colored) (These also hold the Cast top on)
Remove the small door and the plastic hinge guides (put them somewhere safe)
Lift off the whole top and place somewhere out of the way.
On the right side (if facing the stove) look behind the Right Cast Panel. You will see two bolt heads just below the surface.
Loosen (Don't remove) these. The whole Right side Cast panel will lift straight up and off. Again put somewhere out of the way.
Do the same to the Left side panel.
Loosen the bolt holding the convection blower on the left side.
Mark all electrical connection to the blower.
Loosen and remove the bolt from the Right side of convection blower.
While supporting the blower pull it out the Right Side.
Not much to it.
About the only issue I've had when replacing everything is to make sure the Control panel ribbon cable is fully inserted before you put the top panel back on. The daughter board (Control panel) just kinda floats around.
Oh yeah if you decide to run the stove with the Cast panels off.....you have to cheat the magnet switch for the hopper door. Don't ask How I know that.
Hope that helps,
---Nailer---
Top of Stove....
Not much to it.
Hope that helps,
---Nailer---[/QUOTE
One question, when I take the top off I have to unhoke the ribbon cable
From the control board??
Well the dealer came and installed the fan. Hocked it all up and the fan wouldn't come on. Just want to crawl in a hole and cry, so frustrated but all that aside. I've been doing some research, would the POF switch be causing this?? The fan doesn't come on but it shuts off with the #3 flashing. He's gonna call
enviro tomorrow to see what's up. Any suggestions??
I think I found out that my problem is with the wire that got cut, the guy just taped it together but I don't think that's good enough, there is enough wire to connect it to where it needs to go but I need to put a quick disconnect on it, is there a certain size or type I should be using??
