I brought home 1 LP tank today. A pretty, but smelly endeavor.
The tank a used 500 gallon skid type tank was evacuated months ago, and was sitting valve open for 5 months now.
I opened up all of the ports, and poured in 3/4 of a gallon of peroxide ( not enough apparently).
Filled the tank with water, then drilled 2- 2 1/2" holes with a hole saw, ground the paint down, and had the welder weld on the weld-o-lets.
Roll it over, let all the water out, onto the truck & off we go. I found my clothes outside the front door this morning- the odor still strong. At work, I still smelled mercaptin, and finally realized, some water must have gotten on my boots. One more tank to go, then...
We are having 2# polyurethane foam sprayed , so I will have the insulator spray 2" over the whole tank, after installing nipples, and pressure testing.
I haven't read here where anybody has done that yet, so I'll be sure to post pictures.
Chris
Chris
