Hi all! I just actually signed up to this forum, but I've been reading it obsessively for the past month! To introduce myself, I am a young woman who recently bought an old (1800s) rowhouse in historic Philadelphia, and I am attempting to restore it to its former glory... on a budget!
I'm sure I'll have lots more questions for all of you experienced folks, but right now I have three. The house has several fireplaces, and I am currently trying to fit each with a gas stove or gas direct-vent insert, to use as the house's primary heating.
(A) I'm looking for two smaller stoves/inserts for bedrooms in the upper apartment (one to heat a 3rd floor bedroom of about 150 ft2 with 7' ceilings and a ceiling fan on reverse, and the other to heat a 4th floor attic bedroom of about 160 ft2 with sloping ceilings that reach 6' max). I believe the house's insulation is quite poor (I think one wall is just plaster on the outer brick!). I'm thinking of around 6000-15000 BTU a piece for those two rooms - does that sound right? I was thinking either a Jotul DV Nordic 100 or possibly a Lopi Northfield. Or maybe a mini Franklin from Woodstock Soapstone. I have found a few used Jotul Nordic 100s and I'm thinking of buying two - one for each of those bedrooms. As a primary heat source for 150 ft2 in a poorly insulated house, does that sound about right? One would be $450 and the other would be under $800. I've also seen some Jotul DV Lillehammer 200s used - would that be a better choice? Are used gas Jotul stoves pretty reliable? Any years to avoid? Would Lopi be better?
(B) Another stove/insert needs to be larger: it would be in the masonry chimney of the living room of the upper apartment (living room is approx. 250 ft2 and adjoining kitchen is about 150 ft2); whole apartment is about 800 ft2). I'd like it definitely to heat the living room and kitchen, and ideally some heat would flow upstairs (I know that depends on air movement). I'm thinking of getting a used Mendota D-40: it's ten years old and would be $1500 with various accessories included (venting, faceplate, inlay, backplate, etc.). Is a decade-old Mendota likely to be any good? The reason I like it is that the input ranges from 6500 BTU to 40,000 BTU, giving lots of flexibility.
(C) The last stove/insert needs to heat a separate apartment of around 400 or 450 ft2. This apartment occupies the first floor of the building. Ceilings of about 9' (maybe 9.5'), would be installed in masonry fireplace in living room, which bedroom adjoins. Both rooms will have ceiling fans on reverse to spread the air. Because this will be the primary heat source for this unit, I would really like as much turn-down as I can get for versatility. I was thinking of a used Lopi Berkshire. I've seen a few - one from around 2006, one from 2003, and one from around 2001. Have they changed much over time? I'd be paying $500-800 - does that seem fair? If that's not enough heat, I could possibly also add a Rinnai wall gas heater in the bedroom.
Thanks for reading! Really appreciate any thoughts or advice on any aspect of this!
