Have a Lopi Med Flush Wood Insert. I persevered over 1 winter, learning to operate it, and while I did get some heat, I suspect I never achieved the secondary combustion, explained in the manual and comments here. Page 22 of manual says the air control supplies air to the air wash above door opening OK, and through the primary pilot orifice centre bottom door opening. That I cannot find, even even removing bottom fire bricks. Where is this hole? How big is the orifice? It also cautions not to block this orifice when adding wood.
The air control slider, I cannot see the rod attached to any valve though it obviously is, Removing the front face of the insert did not reveal any orifice or valve.
What is needed in this complicated technical setup is a schematic drawing of the primary/secondary combustion systems I see the secondary air tubes, the primary intake is the problem.
I have experimented with the air mixture many times, and it does reduce the burn rate, but usually too much. I find with a hot bed of coals and the air mixture full in, high burn rate, a reluctance to ignite. There is no aggressive bottom draft. Typically I try this before bed time. Playing with the door, or using a bellows will ignite the new wood load but I really shouldn't have to do this.
I have read the explanations and understand the technical details, though I am unable to operate the system as outlined in the manual. A technical diagram would be of great help, also very easy to do. but I have never seen one.
