Still working to get the exact hang of things. I can get a steady 5-6 hours burns with good coals lasting 7-8. This is great when I'm home to adjust the air and reload the stove. On an average day I fill the stove up at 530-6 to have enough time to get it all set by the time I leave around 650am. Then I'm home again between 4 and 530 depending on the job for the day. On a day like that the stove has a few coals that I can restart with some very small kindling and the stove is cool enough that the blower is shut off on its own.
I load the stove e/w. And start shutting the air done as soon as I start seeing temps around 500. The stove top temps (read with an ir gun) run 750-800 and the stack temps read the same after things even out(double wall pipe with probe thermometer)
Last night I loaded the stove around 230. Brought it up to temp and cut the air almost all the way back. Temps leveled off at 750 with good secondary's. Here's a short video![Lopi Liberty longer burn times? Lopi Liberty longer burn times?](https://www.hearth.com/talk/data/attachments/175/175213-2c688d5cdc4cea8da53467a17b2667a1.jpg)
At 730 in the morning the stove was at 250 with coals
. Last nights load was a mix of hard maple hickory and a split or two of oak.
![Lopi Liberty longer burn times? Lopi Liberty longer burn times?](https://www.hearth.com/talk/data/attachments/175/175214-4adc101e53a28de2c7f19fd26851ab9c.jpg)
![Lopi Liberty longer burn times? Lopi Liberty longer burn times?](https://www.hearth.com/talk/data/attachments/175/175215-24df6b5ded686a04f505791505d54888.jpg)
