Hi guys,
I recently purchased and had installed a Lopi Large flush insert Next gen unit. I live in an older brick English Tudor built in 1927 in New Jersey so insulation is poor at best and winters can be pretty rough. can be a bear to heat this house but this insert has definitely allowed me to turn the thermostat down. This thing really throws off a boatload of heat and am happy with it overall. I put a magnetic thermometer on the faceplate just above the door and I can't help but think whatever the temp shows there I should add 50 - 75 degees for an accurate reading inside the firebox. Would you guys agree with that? IS there a better spot I should be placing the magnet for more accurate reading? I feel like when it reads between 350 -400 it really is much hotter!
My other question (which is probably more important) actually pertains to the Firebrick, I have a couple gaps in the Firebrick on the right side and the left side of the firebox. IOW two of the bricks have play between the other ones maybe an inch and half to two inches is a rough guess? Is this a normal thing? Part of me things yes in the event we needed to replace the firebrick and part of me says no maybe there should be no gaps at all?
Here are some of pictures for you guys to see..
As always thank you in advance!
Chris
![Lopi large flush insert question on fire bricks Lopi large flush insert question on fire bricks](https://www.hearth.com/talk/data/attachments/290/290779-9ea94c41acdb0f3085a93cd89fc200a8.jpg)
Chris
![Lopi large flush insert question on fire bricks Lopi large flush insert question on fire bricks](https://www.hearth.com/talk/data/attachments/290/290777-59379fa73ba4a2b240114f2c6e1fe3a7.jpg)
![Lopi large flush insert question on fire bricks Lopi large flush insert question on fire bricks](https://www.hearth.com/talk/data/attachments/290/290778-9ebd931a1f4d6cbc59ab0007bdf2c30c.jpg)
