flash49 said:I'm on my second year with my Lopi Revere and have noticed the hinges are loose. Any ideas on how to tighten them up?
jeeper said:Couple thoughts / questions on that -
1 - Do you mean loose as in the door doesn't seal tight on the gasket (i.e. the dollar bill test) when closed?
or
2 - Do you mean loose as in the hinge pins ride up?
or
3- Do you mean when the door is open and yes, your hinge pins are fully seated there is play in the door to wiggle it up and down a bit?
My Revere is brand new this season and I just checked, yes there is a little bit of Play in the door - example 3 - but when closed it passes the dollar bill test and is in no way loose when the door is closed.
My Lopi Patriot we had before moving was the same way.
