Glad to hear it all went well. My Endeavor had no springs in it either. I also used air to finish off the cleaning. Not sure how they let these things out to the public making that kind of noise, it was really loud.
Is there a good heat proof grease that won't stink when it heats up?
We have had our Lopi Endeavor for 4 years now. Thinking that I'm the only one bugged by the air valve noise until tonight when I went to look it up and found this thread. Thank you for all the info you guys have posted. Now for me...That's it! I'm drilling out my rivets and cleaning it out!
As far as hinge noise... I use vegetable oil because regular oil and silver grease stinks up the house when it burns off. I get about 3 burns out of it then I re coat. Is there a good heat proof grease that won't stink when it heats up?
A little vacuuming and
Strange, the liquid type usually attracts dirt and debris much more than the powder. Glad it worked for you, but this is not a typical result. The powder usually does the trick!Keep the vacuum cleaner away from the air inlet unless you're ready to disassemble again. On mine, the vacuum draws ash from the stove back onto those sliding plates and makes everything worse. I've used the puff-type graphite with some success but there is a liquid graphite lubricant/antisieze intended for engines that I used last time and it has held up much longer. I can't find the stuff but it was permatex brand. It's in the auto parts store with the thread lockers.
TE
This is in the intake which is a cooler location. I used it in the Castine's doghouse to lubricate the slider valve and it worked well.
