That's where I'm at heating 2000 sqft with my stove doesn't sound too far off to meIm through a ton and a half already. My stove sucks
i've also used 3/4 of a 275 oil tank because my stove can't hang on its own. and my house is 1400 sq feet, 1000 of which the stove has a level on (400 is below stove grade)That's where I'm at heating 2000 sqft with my stove doesn't sound too far off to me
Might be a good cheap fix and help his stove out quite a bit. Might keep temps up well above where you are too.For what it's worth, I don't burn pellets... I have 2.2 cf epa wood stove that heats a large 3,000 sq foot home at temps down to -30f with little problem. Right now it is -12 with a north wind of 10-15 and I have to let the stove idle down or it would overheat the place. I do cover the north facing slider window with plastic every winter as it does leak a lot of air and the plastic always bulges inwards showing how leaky it is.
Even the best sliding deck or patio windows are notorious leakers. Up here where it gets very cold, if I didn't do my best to seal my north sliding deck window I figure I'd burn a good 1/3 more wood and I might not keep up with the heat on some cold and windy nights.Might be a good cheap fix and help his stove out quite a bit. Might keep temps up well above where you are too.
Agreed. Glass in general is a huge BTU killer. Pieces of glass that move are even worse. Cold air infiltration can make heating a place a exercise in futility.Even the best sliding deck or patio windows are notorious leakers. Up here where it gets very cold, if I didn't do my best to seal my north sliding deck window I figure I'd burn a good 1/3 more wood and I might not keep up with the heat on some cold and windy nights.
it's not so much the R value of the glass but how well it seals out the air drafts. I think casement windows are better at that than others but I could be wrong....The dumbass that built my house put 70% of the windows on the north side of the house. This includes 2 patio doors, 2 man doors and 1 POS French door! Live and learn. It doesn't matter how much insulation you use, the best windows are only about R 5-7! You could have the best stove in the world, but when you try to heat the planet instead of the inside of your home, you're fighting a loosing battle!
Brian mine did to well still does but not as bad when I moved in here. I had to take the molding off of the inside door to plug a 3 inch non insolated gap all around it. My wife also bought some thick winter drapes for the slider door that help allot. Also no insulation around my down stair window jams either had to do the same with all of them and my outside wall electrical platesmy slider leaks like crazy
How trueYou could have the best stove in the world, but when you try to heat the planet instead of the inside of your home, you're fighting a loosing battle!
I'm on the south shore of a lake! Right now its -10 at my house wit 50 mph winds coming off the lake. I'm 20 feet away from the stove and can actually feel the wind! Lol, can't wait to build the next.When I planned for the build of our house we did not put any North facing windows. Would just get some road noise and look at wall of evergreen trees 20 feet away. Office in the one room and AV room in the other and both north walls are use for idiot boxes. Very good move when the winds are like they are tonight at about 15 from the NNW and its -10
I'm on the south end of a lake also and it can get wicked! But 50 mph winds are seldom up here. You are doing good if your keeping warm at all in those kind of extreme winds and cold, cold temperatures!I'm on the south shore of a lake! Right now its -10 at my house wit 50 mph winds coming off the lake. I'm 20 feet away from the stove and can actually feel the wind! Lol, can't wait to build the next.
The funny thing is, when I had the wood stove, the windier it was the hotter the house would be! I went through a lot more wood, but holy crap it got hot down here! Some times I had the damper fully closed and the stove was still crazy hot! The pellet stove is a lot more in control due to the mechanical draft.I'm on the south end of a lake also and it can get wicked! But 50 mph winds are seldom up here. You are doing good if your keeping warm at all in those kind of extreme winds and cold, cold temperatures!
I don't see that, maybe cause all my windows are south facing. 40% of my south facing wall, is basically floor to ceiling glass, with one slider. That slider opens to a patio completely of glass, 5 double sliders.Agreed. Glass in general is a huge BTU killer. Pieces of glass that move are even worse. Cold air infiltration can make heating a place a exercise in futility.
Your glass is on the right side for winter and helps with solar gain. If you take into consideration the R-Value of glass and hot / cold transfer an insulated wall without glass is better in any situation. On the flip side how does all of that glass help you with cooling in the summer. It hurts you. Also that glass hurts you for heating on non sunny days in the winter because the glass cools and there is no warm sunny love. Low-E, argon, and stuff only goes so far.I don't see that, maybe cause all my windows are south facing. 40% of my south facing wall, is basically floor to ceiling glass, with one slider. That slider opens to a patio completely of glass, 5 double sliders.
You have it figured out. My point is what happens when that patio / sunroom isn't opened? The ocean breeze most definitely helps tremendously also. What happens when it isn't sunny in the winter? Glass works against you. Does it not? There is no perfect solution for any home. You have to make adjustments accordingly. Too many variables. I am sticking to my guns on glass having poor R-Values and tons of losses and gains. There is just no way around it.In the patio, there are also 3 45x 40 skylights that open. In summer, we open all the sliders, the patio door into the house, and the opposite wall windows to get a good cross breeze going, we also live 1/2 mile from the ocean, so the breeze is more mild in summer.
