Nice! Let us know how it goes. There is a thread on right from someone who has problems getting theirs to operate the stove. Smokey & I both gave help and instructions on how to set it up.Thanks Imac.....I'll be "proceeding to checkout" in a mere minute
5 DEGREE SWING???????????? No way in hell would my wife tolerate a 10 degree change in temperature every hour Actually if you let the temp drop that far, it will continue to fall several more degrees before the stove stops the fall in temp. IMHO that is WAY to much swing.Make sure you get a thermo with a large "swing". The above lux does.. most crappy cheap thermos do not. Need 5 degrees at least for a pellet stove imho.
Correct me if I'm wrong, but I thought each "swing number" was equal to .5 of temp. A swing of 5 is actually only 2.5 degrees.5 DEGREE SWING???????????? No way in hell would my wife tolerate a 10 degree change in temperature every hour.....
