It would be no big deal to add it in the future. It's something you could do if you think you need it. But I really doubt you will see any difference at all.Yep just the fireplace...........more decisions.
It really depends on the house construction and sealing. One way to check is if you open a nearby window a little bit. We have a window right next to our corner installed stove. I have tried cracking the window open under all sorts of conditions and found no change in the way the stove burned. Conclusion, an OAK would do little to change our stove operation. This is because we have an old farmhouse that is not tight. Your mileage may vary.
Ah but stove operation is just one of the benefits. You are also get to keep your conditioned room air instead of exchanging it for cold, dry outside air. My house, on the wet side of WA, hangs for weeks on end with the hygrometer (humidity meter) bottomed out at 16%. I want the humidity to stay. Drafts, comfort, all better with OAK.
Could be the house interior is being heated much hotter than we keep it. Our normal interior temps are around 72F and our normal outdoor Dec temps are in the low to mid 30s for about a 40F differential. Normal outdoor humidity at that time is between 90 and 100%. Or maybe the hygrometer is not reading accurately.
Sounds like the real issue is that the house is leaky and drafty. Time for some sealing and insulation.
No doubt! However, both tightening up the house and the OAK as Highbeam suggests makes great sense.Sounds like the real issue is that the house is leaky and drafty. Time for some sealing and insulation.
