Hi,
I have a 20 year old home and have decided to replace the outdated tile around my gas fireplace (corner fireplace). The tile was outdated so I decided to go with a stacked stone design. This is the stone I've decided to use:
https://www.menards.com/main/buildi...2-c-19691.htm?tid=-6303989779778476630&ipos=2
I've tore off the tile and removed most of the drywall around the fireplace. I'm planning on using 1/2" durock with a vapor barrier behind it. I've run into a couple roadblocks though and am looking for advice. I've attached a "before" picture and a picture of where I'm currently at.
Here's my issue: I was planning on tearing out the drywall all the way to the wall corners and mount durock. Once I tore into it, I realized that there are no studs on the corner. I stopped removing drywall where its still connected to the last stud.
Where do I go from here? Can I use a combination of durock and drywall? The strip of drywall remaining on each side is about 4.5". Do I need to remove all of the drywall? I'm planning on running the stack stone all the way to the corners. If I used a combination, I'd have about 12" of durock and 3.5" of drywall on each side. Would this work? If I can use a combination, what do I use for the joints?
Thanks!
![Looking for advice - Stacked stone fireplace surround Looking for advice - Stacked stone fireplace surround](https://www.hearth.com/talk/data/attachments/241/241627-20cbfd5c23b41ae56d676a068620c6df.jpg)
Thanks!
![Looking for advice - Stacked stone fireplace surround Looking for advice - Stacked stone fireplace surround](https://www.hearth.com/talk/data/attachments/241/241626-7788421d2b5d4aaa51c3dd24ee28c02f.jpg)
