SnowTraveler, You have a 500 gallon and a 300 gallon tank for storage. Did you start out with just 500 and then add. The reason why I'm asking is I'm going to increase my storage from 500 and I'd like to know how much of a difference it will make.
Last heating season was the first for my Garn we heat a 1912 farm house three story 4000 sq ft newer windows and good insulation DHW and heat slab heat in a 20ft by 60ft 16ft ceiling and keep it at 45degrees all the time. we heated from Oct to easter last year as I got hurt easter and couldn't load the Garn any more. We kept the house at 75 degrees all the time and I run the Garn up to 210 regularly. I burned a true 10 cord of hedge last winter but we had a very cold winter we had not seen in years. I think I will be at closer to 8 cord this year or less it has been a warmer winter so far. I if was doing it again I wouldn't spend the big money on a gaser.There are only two house in the mile I live in so the smoke is a no issue I would build my own burner add storage down from it. I have another 2000 gallon stainless storage tank on the trailer in the shed for next year so we can be gone longer between burn. I won't mind burning less wood but I don't like being cold that is why I went back to burning wood. I have a whole pasture of wood that needs to be cut.ihookem said:One thing I know for sure. If I turn the heat to 72* my furnace runs a whole lot more than if I keep it at 68* I will bet I use 30% more wood @ 72*. Another thing I noticed is many keep their temps @ 180. I found I use a lot less wood @ 165. 165* is enough heat to maintain 70 * in th ehouse no matter how cold outside. I guess If I keep temps @ 180-190 like some do and then keep 75* like post # 46 I would use 7 cords instead of 3.5. This most likely is why some burn 8 cord, some burn 4. I burned 3 1/3 cord last year and a bunch was popple and box elder. It was a fairly warm winter though.
