I have started use deep cycle in my truck .I make too many short trips and the regular batteries just dont hold up in those conditions. If i add a higher amp alternator it would make an excellent generator although use a lot of gas.
Even though it's a big battery (495lbs) it's listed at 18 kw/h. I know it's juice in it's pure form so let's say 90% efficient. If a gas generator (5kw) is only 30% efficient, and runs about 1/2 the time doing nothing it's true efficiency is only 15%. You could do better by shutting down and only using a few hours/day but I don't roll that way. I'm a (bt)user.Agreed ,it would be a shame not to be able to use that huge energy storage contained in a fully charged volt drive battery. What a great commercial ,the whole neighborhood is dark except 2 house all lit up cuz they have volts in the driveway hooked up to their power supply.
Yeah I figured the comment about solar credits was too good to be true.
In any case I really should have a battery backup pump. If we lost power while Im at work in a situation like the 2010 rains the basement would flood before I got home. Piecing one together from components with a bigger battery to have the option to run the inverter seems to make sense. Adding the solar panel is more for a fun project than anything else.
On a bang for the buck basis the smart move would probably be to get one of these HF 2 stroke jobs.
WG
Have you considered a water powered sump pump? I just hooked up one and that baby pumps some serious water.
I did but nixed it b/c I wanted something 'automatic', and for the water power then it would have to be hard plumbed and in my finished basement that would be tough to run the supply. During Irene my mid-size Zoeller primary was only running ~50% duty cycle (for about 36 hours). The battery guy could (nominally) cover that w/o help.
All this talk of combinations of bigger and smaller generators makes me wonder if you use a smaller, quieter, efficient generator like Honda 2000 augmented with some batteries and an inverter/charger to handle both the constant loads like lights and fridge as well as short-term higher loads like well pumps.
You could either run the generator constantly and use the additional capacity of the batteries/inverter only for high loads or (more elegantly) you could size the battery/inverter combination to handle all loads with the generator coming on only as needed to recharge the batteries. (I realize that this generator is not electric start but I'm talking conceptually here).
The battery/inverter setup (basically a UPS) could handle short outages without any generator.
Doesn't sound cheap or easy though.
Since we are talking pumps. Our problem is a stone basement and a high water table. In 2010 the spring rains started to overwhelm our primary 1/3hp and it was running 24/7. So I want a backup capable of 2000+ gph @5ft
In that size range Im looking at around $800-$900 for a decent system. One example is the Zoeller 510 which uses a high quality 12v Marine bilge pump (Rule 4000) and gets about 6 -7 hr runtime on an 80Ah battery. But its almost $700 before you even buy the battery!
Doing some investigation I determined I could piece together my own setup using individual components, and add more capacity and extra house backup capability for similar money.
A setup Im considering:
Rule 4000 pump (10A @ 12v) - $200 (from a marine supply house)
piping and float switch - $75
Universal Battery Group 4 deep cycle 200Ah 12v - $350
Powermax 35A 3 stage deep cycle charger/maintainer - $100 (from solar/backup power supply houses)
Xantrex 600watt pure sinewave inverter $150
wiring, box/misc $100
Total: $950
For about $100 more than a canned system I get over double the backup pump runtime and the ability to run some light 12v and 120v loads around the house. In a long outage I could charge the battery off the generator for 2-3 hr twice a day and run the pump, laptops even a small TV all day. Also the battery and charger are probably better quality and longer lasting than the stuff in those canned battery sump systems.
This is just one option I pieced together on a couple hours research. I am going to do more research before buying anything.
I'd like to get to the point where I need the generator only to charge a battery bank - the battery bank could manage all loads (not simultaneously).
I had drawn up a similar system at one point, and thought about getting a magnum inverter/charger that would autoswitch a couple 120V circuits (for $600 more than your charger and inverter)....but never pulled the trigger.
Not really - my disclaimer in ( ) of "not simultaneously is key. The biggest draw items I have are my well pump and sump pump.That sounds like a big battery... like off grid house size.......
The best water situation I can think of is artesian well or spring above house level coupled with a cistern feeding into the house via gravity. Of course, I'm sure our modern landscape is just teeming with properties ripe for this setup!
