My first post,
I have a speeco splitter with vertical shaft motor/pump . Pump sits below it at about bottom of a oil tank level. I would like to change the motor on it and put one with horizontal shaft but ... the pump would sit about 4" above hydraulic oil tank.
Question:,
1. Would it be OK if the pump is higher then oil tank?
2. On cold start, would it have oil in it or run dry for few seconds?
3. Any issues with cavitation etc?
Thank you.
Question:,
Thank you.
