Hello everyone, first time poster here. I've already learned a ton from this forum by lurking, and thought you all might help out this stove novice with changing out an existing stove/chimney install for a new one.
The picture below is of the log cabin I got a few months ago, as the owner left it. The place is around 1700 sq ft, with log walls and insulated roof, including basement. Pictured is the living room with cathedral ceiling, to the right are stairs to an open loft located over the open kitchen and two small bedrooms. There are ceiling fans. Basement is half underground on a slope, with cinder-block foundation walls. There are electric baseboard heaters. The cabin is in the mountains of West Virginia, so it can get pretty cold in the winter, normally in the teens to thirties, and down to -15 F during real cold snaps.
![Log Cabin Stove Replacement: Questions/options--Drolet Escape 1800 Log Cabin Stove Replacement: Questions/options--Drolet Escape 1800](https://www.hearth.com/talk/data/attachments/118/118153-91fe109242000a517cc56537256f2cf9.jpg)
The existing stove is a cast iron DutchWest cat. I have not fired it up. How many things can you spot wrong with the installation? (never mind the decor)... The previous owners were lucky they didn't have a fire--the wall behind the stove is somewhat charred/stained, stovepipe too close, leaking and rusty. Stove seals shot. I don't think that kindling (in a paper bag in a plywood-lined compartment!) has minimum clearance, etc...
After removing the masonry wall:
Here is the plan:
1. Completely remove the existing hearth and stove
2. Put in new hearth: one-inch slate slab on the floor (on top of 1/4 inch Durock), corrugated metal wall shield
3. Put in new stove (I think I've narrowed it to the Drolet Escape 1800)
4. Have new chimney and pipe installed (through existing roof cut)
I keep thinking the Drolet because it's reasonably priced, has low clearances, is relatively compact depth-wise so it won't stick out far into the room (still can be loaded NS though), and I like it's clean/classic look (would get pedestal w/ nickel door).
Questions:
--Is this a good stove choice for the space described? Has 2.3 firebox and seems like a burly medium-size stove, but I have only seen a few reviews. Will it be enough for a log home? I figure the baseboard heating can keep the place from freezing when we're not there (second home), while we crank the stove when we are. Would be especially interested in any first-hand experiences, especially regarding burn time.
--I also considered Timberwolf 2200 (too small/durability?), Napoleon 1400/1450, PE Super 27 (would protrude into the room more, not sure they are worth extra cost?).
--I read that this stove (Drolet) needs to have baffles removed or quick release flu (?) for chimney cleaning: How much of a consideration should that be? Any owners out there? Deal breaker?
--Chimney: what about single pipe vs. double - any issue with using single wall pipe? I was thinking it could help heat the room (was planning to bringing wall shield behind the pipe all the way up).
Wow, thanks for reading this far!! I'm sure I'll have more questions as I go along...
![Log Cabin Stove Replacement: Questions/options--Drolet Escape 1800 Log Cabin Stove Replacement: Questions/options--Drolet Escape 1800](https://www.hearth.com/talk/data/attachments/118/118182-11ee9bc1edf6a27fdd064440ac744bee.jpg)
Here is the plan:
Questions:
