I've read somewhere that Locust is a decent burning green wood. I know it's top notch when it's seasoned and heavy as heck. I have loads of it but it may be a little too green for this year.
savageactor7 said:I know I'm in the minority here but imo Locust is the biggest pita wood there is...and that's when it seasoned 2 years. There is no way you could possible get a stove hot enough to burn fresh cut Locust.
If you're short on seasoned wood get some pallets or bio-Bricks.
Chief Ryan said:I had to look up PITA to know what you meant. Why do you say that?
I agree that locust does produce a ton of coals. You bring up an interesting concept, that being that too many coals can be a PITA at times. In bitter cold when you really need max heat output all the time, coals can load your stove and while they give off good heat, it isn't maximum heat. Perhaps mixing woods that don't coal as well could be helpful in those situations, though for the longest heat producing burn possible, locust is awesomesavageactor7 said:Chief Ryan said:I had to look up PITA to know what you meant. Why do you say that?
When it gets cold up here you need fire for warmth, Locust just loads the firebox up with coals that last forever. Great wood to burn if you're gonna leave your house for 14hours though....but that ain't us. I know its very highly rated btu wise but in our application being in a big civil war era 5br farmhouse we need firepower...not coals that are so long lasting that they prevent you from reloading the firebox after a 6-8 hr burn.
When we first moved here we had a lot of Locust now we just have a few trees about 1000ft upwind to enjoy the pleasant smelling blossoms. The trees have a tendency to take right over and crowd out other varieties too. We brush cut the saplings as an evasive species. Just remember to season it for a couple of years...it's like oak that way.
Also the thorns will flatten your tires...
...like I said I'm in the minority here. I supposed if I had to do it all over again I would have cut other trees to mix it up with but I had so much of it that's all I cut at that time...that is after I got a few flats.
Chief Ryan said:I've read somewhere that Locust is a decent burning green wood. I know it's top notch when it's seasoned and heavy as heck. I have loads of it but it may be a little too green for this year.
