Hello all,
I've been reading this forum for a bit over a year now and finally got a new stove and actually signed up to become a member![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
After a year of research (a lot on this site - great posts and info by many of the members here.) I finally got a T6 to replace my 1988 VC Defiant Encore. The VC came with this house when I bought the house several years ago. It was always a finicky stove and I had to baby sit the thing or it would smoulder or over fire, also had CAT issues and just never liked the stove other than its looks. I also built a big addition on the house so wanted a bigger stove with a heating profile more like a non-cat so I settled on the T6.
I just set if up a couple of weeks ago and was worried about my 6x10 lined chimney and draft problems. I would not be able to fit a 6" liner down there so figured I would try it and worst case put a 5.5" liner if I had problems. Anyway, even now in NH with temps in the 40s, I get secondary burn and the stove cooks. I know I will really enjoy this stove, I can tell already after only 6 or so fires but it is drastically different than the old VC I've been running. So I now have a couple of questions that I hope some of you can help with.
1. Even with the stove only 50% full, I get surface temps in the 700 range with the stove turned almost all the way down. Very good secondary action but I worry that when I fill the stove, it will over fire if I walk away or go to sleep. Do I just need bigger splits? My wood is dry. Measured fresh splits at about 13 - 15%. My wood was cut pretty small because I was running the VC pretty hot and it needed smaller wood to stay hot. I would say the biggest splits I have would fit 3 or 4 across the bottom N/S.
2. How can I "fill" the stove? how high up on the inside should I go? Can I fill right up to the baffle or should I go only maybe to the height of the brick? Should I stick small pieces in any gaps or will that cause it to get too hot? Any chance somebody can take a pic of a "regular" load? I've been changing the way I do it now but have not stuffed the stove "full" but I dont get overnight times either.
So much to learn about this stove but as I mentioned, I already know I'll like it a lot.
Thanks for any input
