OhioBurner© said:1]Braking should just be common sense... as you'll rarely ever load wood up in a truck more than it can handle braking - I mean most half tons today can tow 5,000-to nearly 10k #. In a short bed heaped your probably looking at 3,000 or less for sure. Yeah you'll need more distance for braking but it should be well within specs loaded or overloaded.
KarlP said:OhioBurner© said:1]Braking should just be common sense... as you'll rarely ever load wood up in a truck more than it can handle braking - I mean most half tons today can tow 5,000-to nearly 10k #. In a short bed heaped your probably looking at 3,000 or less for sure. Yeah you'll need more distance for braking but it should be well within specs loaded or overloaded.
The current generation of trucks stops a LOT better than their ancestors. However, if you read the owners manuals midsize and 150/1500 series truck makers still say you must have trailer brakes if the trailer weighs more than 1500 or 2000lbs. Trailer brakes make a HUGE difference.
OhioBurner© said:timfromohio said:Its amazing what just a little 2" lift and some slightly bigger mudders can do.
I'll have to respectfully disagree with you on the mudders for snow. I have found them to be terrible compared to an all season radial or a mud and snow tire in the snow.
I use my truck as a truck and it is used off road collecting firewood. the terrain is pretty steep here in the mountains and I have to use 4WD a lot. I can't think of one situation ever where a lift would have helped me. Then there is the changes to the drive train geometry that do not make it stronger, though 2 inches should not be bad.
KarlP said:The current generation of trucks stops a LOT better than their ancestors. However, if you read the owners manuals midsize and 150/1500 series truck makers still say you must have trailer brakes if the trailer weighs more than 1500 or 2000lbs. Trailer brakes make a HUGE difference.
Well your right about common sense lol. And my point about the payload vs towing rating pertains to trailers without brakes... it shouldnt matter much if the weight is on the trailer or on the truck as far as the brakes are concerned. If a truck can tow X amount of weight without extra trailer brakes, then it can haul the same weight in the truck (as long as it doesnt exceed the trucks payload capability). I'm just muddying up the waters though, shouldnt have mentioned it.jotul8e2 said:Good thoughts, but unfortunately there is nothing less common than common sense. You can easily load an 8' bed on a 1/2 ton pickup to well beyond its load limit with hardwood. Shortbeds, probably not. What a truck can tow and what it can carry are two entirely different things. A trailer has its own suspension, tires, and if of any size, brakes. The current typical Ford F150 has a load rating of maybe 3,000 lbs., but a 10 or 15 year old model may well be a third less. As for risking log launch, how many of us have been guilty of tossing on "just a few more" after the bed is level full, with no netting, headache rack, or anything? I can't be the only one.
MarkinNC said:I'll have to respectfully disagree with you on the mudders for snow. I have found them to be terrible compared to an all season radial or a mud and snow tire in the snow.
OhioBurner© said:KarlP said:The current generation of trucks stops a LOT better than their ancestors. However, if you read the owners manuals midsize and 150/1500 series truck makers still say you must have trailer brakes if the trailer weighs more than 1500 or 2000lbs. Trailer brakes make a HUGE difference.
Yeah I didnt figure in that those tow ratings factor in having trailer brakes. And once you go back a couple of generations yeah the braking sucks on the older models.
I wasnt aware in NY there was a set limit for trailer w/o brakes regardless of tow vehicle. Been several years since I lived there. It doesnt surprise me though they are getting pretty out of control with all the rules there. After pulling various trailers with my F350, I'm not even concerned with trailer brakes at the 3,000# area, which I pull frequently. Now I do also pull that plus nearly a cord in the bed so the weight adds up, and I do want to put a bigger axle and brakes on it.
Yeah 2" isnt a big deal but it has helped me plenty of times. In fact I've been beached or high centered or whatever you want to call it a few times even with the lift, bigger tires, and short wheelbase. Luckily my buddy was there to help and we always got it freed up. I imagine with a few less inches of clearance we would have been stuck for good but thats just a guess. I dont believe in jacking a truck way up.
About the only time I have found MY mudders to be worse than all terrains is on the road, so I also have to respectfully disagree. And I have taken AT's in snow up to the bumper several times so I do know they are good. And not just Ohio snow but northern NY snow. Now like I said on the road a good AT is better. I do have 2 complete sets of 4 tires, one set with the AT's and the other with the Kumho MTs. I think the specific pattern really makes a difference too. Most mudders have huge smooth lugs with no siping and big gaps. The ones I got have much smaller tightly spaced lugs more like an AT, and I have had them siped. I also have a set of super swamper TSL's on my 78 bronco and the Kumho's literally have over 2 lugs for every 1 of the super swamper. It also makes a difference what the terrain is. If its firm and light snow the AT might be better, if its sloppy or packy like it is here most the time the mudder has done be better. I can't seem to find a pic zoomed in of the tires but in this one you can see the lugs are smaller and closer than most, kind of like a hybrid mud/at tire:
aussiedog3 said:I work at a sand, gravel and stone supplier. See pickup trucks loaded all day long.
Thought truck companies should film their commercials at our site.
Nothing handles the weight like a Dodge. Way to go Danno.
I've seen 2.99 tons go out on an old half ton Dodge, barely squated.
Yeah then you are correct, I can't really think of any situation on the road that mudders would be better. Well... maybe a few but I'm really fishing here. Yeah the ones I have are very mild for a mudder, and even though they were quite a bit larger than stock, it seems trucks now-a-days are comming with tires that big already. They are 285/75/16 and my stock was 255/70/16. I think we are going off on a tanget though...MarkinNC said:I was specifically referring to tire performance on the road. Those tires pictured are not what I had in mind when I read mudders. I was thinking of a wider tire.
MasterMech said:KarlP said:OhioBurner© said:1]Braking should just be common sense... as you'll rarely ever load wood up in a truck more than it can handle braking - I mean most half tons today can tow 5,000-to nearly 10k #. In a short bed heaped your probably looking at 3,000 or less for sure. Yeah you'll need more distance for braking but it should be well within specs loaded or overloaded.
In NY (many other states?) It is required, if a trailer is rated to carry over 3000lbs it must have it own braking system. Take a look at your local TSC or Lowes/HD. Their trailers are all rated at 2999lbs GVWR despite having 3500lb rated axles under them. That avoids the cost of having to install electric brakes.
I've seen some scary tow rigs out there. Usually low-budget landscapers/lawn maint guys that bought a used trailer and never put a controller in the truck. I'm glad to see that HD 3/4 and 1 ton trucks now are coming with trailer wiring (7-Way) and brake controlers pre-installed as a factory tow package. IMHO this needs to be extended to 1/2 ton trucks too if it isn't spreading there already.
The whole "Drive Carefully" philosphy is great but doesn't take into account others who may run lights/stop signs or any other unexpected events.
