To clarify, the bricks I had to knock out were in the chimney not the stove.
I would definitely follow Woodhound's advice if you can. I had less than an inch of clearance to work with on top of the stove, which I suspect is common, so I don't know what they do in that situation other than just use the weight of the liner.
What do you do Woodhound? There certainly wasn't room to get at the top of the L bracket, never mind 3 of them
If there was a small loop at the top of the collor or L bracket, you could use a stainless steel zip tie, have it set up with the tail towards you before inserting the liner and you could tighten it in less than an inch of space.
It seems a bit absurd the manufactures ignore this probably common situation.
Good luck!
Good luck!
