I’m stuck on a Chimney liner install. It is a 6” liner, pre-insulated stainless liner with outer liner. We did a bottom-up install. It was very difficult with the double bends in the chimney and the sharp, grabby masonry.
![[Hearth.com] Liner Install - outer stretched in relation to inner liner [Hearth.com] Liner Install - outer stretched in relation to inner liner](https://www.hearth.com/talk/data/attachments/317/317241-c0c8f3af35b25c370306fa9c205a8062.jpg?hash=4-GC4_IZIK)
We eventually got it through, and the top is extending 2” proud of the flue tile top. Flue tile size is 12x12”. Total length about 25 feet.
Looking down into it from the top, the inner lining is retracted from the outer liner insulation sheath by about 3-4 feet. It appears compressed in relation to the sheath, judging by how curvy it looks in the picture.
![[Hearth.com] Liner Install - outer stretched in relation to inner liner [Hearth.com] Liner Install - outer stretched in relation to inner liner](https://www.hearth.com/talk/data/attachments/317/317242-f40bdb7d0df5a396cf3d61eda45b29e9.jpg?hash=uiT9la59EY)
I have already cut the excess liner length and have about 2 feet still hanging out into the fireplace.
![[Hearth.com] Liner Install - outer stretched in relation to inner liner [Hearth.com] Liner Install - outer stretched in relation to inner liner](https://www.hearth.com/talk/data/attachments/317/317243-dd514500bd5d2f036f9d096b0ac573dd.jpg?hash=ibh7xI5E-_)
Another constraint, is that the top of the chimney has a concrete slab cap that I want to keep intact. I could cut an access hole above the flue and patch it later if I have to though.
Do yall have any ideas, on how to get the proper, stainless inner liner to reach closer to the top of the flue? I could push it up the remaining amount the is still in the house but it would still be short of the top.
I can’t think of a way to grab only the inner liner pipe to pull it more taut – any ideas on how to pull that up to take up what appears to be slack?
Or any ideas on how to insert some extra 6” liner to meet the inner liner that is still short of top? Maybe a couple of crimped and inserted pieces like so? I wouldn’t be able to fix them with fasteners though.
Thanks for any thoughts! This site has been super helpful already just for lurking and researching before I even started.
