One of my issues may be that the stove pipe is just right for the stove. Meaning, I would really have to screw up to overheat it. On the other hand, fear of overheating is causing reluctance to burn to potential. Twice the stove went unattended for 30 minutes with full loads. Both times the max temp was 800 or just under. If in fact the draft ability of the setup is limiting the burn to 800, I can let her run without such concern. Is that a viable possibility?
On another note, I tried the blower today, along with identifying and somewhat correcting an issue of air flow in the basement (a space that was segregated last year and is no longer due to doors/walls removed from flood) and the result was noticeable. Outside was 26 and house was at 73. Going to keep the blower running tonight. Looking for 68 or better in the morning as a positive result.
