Thanks I just found that on my own. I does not contain any real data, only government assigned values (all pellet stoves are created equal).
Thanks for trying.
I have very similar stove (Timber ridge insert) and I just tried the Green supremes and the stove runs very well. Very large flame when set on just 4 (auger speed) and 6 (blower speed). Was able to get a large great room (18 ft ceiling) to 75 from 65 in about 2 hours no problem!it seems like everywhere I go I find a stove that is blowing out wayyy hotter air. My neighbor has an old Breckwell and that thing cranks it out....they can't even have it higher than the lowest setting or it blows everyone out of the room. Another friend has a Regency greenfire and it's the same deal. I looked at Harmans and Enviros today and it's the same thing.
I have a 25-pdvc and a 10-cpm and I can't get them near that hot. I've adjusted and adjusted and adjusted. I"ve burned american wood fibers and green supremes over the last 2 years. I think they're functionally fine and they've been good, reliable stoves to this point. But I have to admit it's frustrating that I can't get that kind of heat of out of them. Is it just the heat exchanger design? I can't seem to get the blowtorch like flame that other brands generate. I've read that you don't want a flame as active as a blowtorch, but it seems like that's the ticket to heat. The Harman I looked at showed over 400 degree air coming out of the front of the stove!
Like I said, I love the englanders and Mike has been awesome on this site. I just feel like something's lacking with the btu's.
My internet was super slow yesterday. I couldn't even watch a movie without it 'buffering' all the time. I pulled the plug on the modem/router and plugged it back up and away it went back at full speed. It's worth a try!Thanks bear!
My turn for a slow internet sevice day.![]()
On the PDVC there is a choke plate to limit the amount fed to the upper auger. It can only be adjusted when the hopper is empty. There is also a low fuel feed adjustment (one of the three magic buttons) that can be used to trim the fuel feed at low settings.More heat in (pellets) equals more heat out, hence the 'very large flame'. Does Englander specify the correct flame height for a particular auger speed? Flame height/lbs per hour depends on the pellet size at any set auger speed so there should be some kind of adjustment to prevent over firing.
i'm in D mode by the way
Not all pdvc's have a fuel gate. just sayn.On the PDVC there is a choke plate to limit the amount fed to the upper auger. It can only be adjusted when the hopper is empty.
you do realize someones gonna yell at you for doing that.
It won't be me. good job!
Good ash traps!
Actually those on top are the ones i laid on the heat exchanger. Took a pic before i put them in the slot so you could see how many.Thats gotta work pretty good. The ones on top are just added radiant bonus!
Yeah, i thought about using thermal compound. I use alot of in my line of work. That stuff is so messy. I figured it was not worth the headache.Try some of that thermal compound that is used to join the heat sinks to them thar 'puter type devices.
Speaking of which would a nice 4.2 GHz 8 core amd unit make a speedy home system?
Ash won't even touch em. They are just pulling heat off the top of the heat exchanger.
namely milking a stove for all the heat you can get out of it.
