Lenght of pellet stove chimney???
Im not talking about any smell in the house but out the end of the venting.
I dont know how many of you have had your nose at the end of a pellet vent when it is running
but I think it stinks. and I have been around 1000's of running stoves.
But some people like the smell of my farts also. LOL[/quote]
If you burn good Pellets its sweet smelling.
hearthtools yep I knew exactly what you were talking about
and like I said I never smell anything coming
from the stack except a wood burning smell.
Maybe something wrong with your sniffer eh?
Guess it's a matter of opinion but you're def
in the minority and so is the poor soul
who likes the smell of your farts.
ROFL! Come on, Rod! You just made me spit coffee on my screen with that fart comment! Too funny! :bug:
Peggy
dear pedsdpt,
I terminated my pellet stove thru the wall , but my pipe comes out about 18 inch or maybe 2 ft before terminating in a vent hood as you see in the picture. My wall never turned black, but if i did, i couldn't see it anyways because the wall is dark brown.
I do notice ,when the wind blows just right, or maybe I should say just wrong,
that I get ash on my car, which is a good 80 feet away from the vent & on the opposite side of the house.
Happened several times last year but not once this year, go figure.
If your pellet stove was lite when the power failed,without the up pipe, you might get smoke back into the house. If your stove was off,you certainly could not start it without power.
I figure there are maybe 6 chances out of 100 that I get stuck with my pellet stove going when there is a power failure, not enough to make me change my setup.
I bet it cost you an extra 150.oo to go up that 5 ft. I would never bother, but on the other hand, there is merit to what they say & if the power did fail while the stove was lite,you might get some natural draft, or maybe not enough, depending on the length of the up pipe.
So,let personal preferance rule.
So,let personal preferance rule.[/quote]
It happened to me last year and smoke went into the cellar. thats where the stove is.
hearthtools, you made a comment about venting under a deck before. What is wrong with that?
My stove was installed by the dealer under my deck. we have a ranch with a walkout cellar. so the deck is for the second floor. like a raised ranch.
We never had the sliding door open when the stove was on.
My stove is vented right outside the wall. I don't have a chimmney. This stove has been here for about 6 years (I just bought the house a year ago) I would like to have the pipe run up above the roof. If I should lose power how does the smoke get in? The door is sealed pretty tight. Also, how do I find someone who can do this? I'm in Connecticut.
Thanks for your help.
Along this line, I want to put a furnace in my basement that has an existing double walled metal chimney running to it. It is a 6" diameter pipe and runs about 30' up to the roof. Specs for the furnace say 4" pipe is recommended. Is this to long or pipe to big?
I Never said anything about venting under a deck
you should never vent any pellet stove UNDER and incloser
Whops... it was stoveguy2esw
Was just curious what is bad about it? We have an install this week of a Mt Vernon AE in a basement. It will get 3-5 of rise inside then go though the wall and terminate under a deck. All clearances will be maintained and the deck is freely open underneath. I scoured the install manual while I was there and could not find anything suggesting this was a bad idea. The guy would rather get some crud on his siding than cut a hole in the deck and run the vent up through it. It would end up being one really tall chimney due to his roof pitch.
Hey if you have 5 feet or more from the vent try it
but I Bet in a month or so you will see some black Cob webs on the under side of the deck.
I just started my Big E pellet stove,i only get white smoke at the very beging and no black smoke ever. Is there something wrong??
John
John
Just because you CANT see it does not mean it is not there.
It will build up in time.
and Yes the start up and shut down mode is where the most PARTICULATES come out of the stove.
John
My wall has nothing on it at all. It must be the cleanest going.the smoke stops when i see flame.
hearthtools said:
I will NEVER install A DV pellet venting not just from the soot but WHEN the power goes out smoke WILL spill into your home if you do not have a vertical rise to draw the smoke out of the stove.
You can get much more accurate air adjustment out of your stove if you have a vertical rise
Also Pellet exhaust Smells bad
If you have an window near by it could come into the home.
I know this an old thread but can one have the vertical rise inside their home, ie 90 off back of stoce with clean out T, up 5 ft, then a 90 and go out 18-24" past the siding with a turbo cap?? Also add fresh air kit directly off back of stove, so it would be 5 ft lower??
I am considering a pellet stove but do not want 20 ft of exterior chimney.
Odds are that depending on the stove, you won't need 20 feet of pipe. My englander only has a minimum required 3 ft. rise. It seems to work quite well.
