D8Chumley
Personally I get nervous when my stack temp goes over 500, especially if I'm loading for overnight but that's just me. That runaway fire in the old stove still haunts me
That brick must have hurt.
The flames were very clear and were blue, purple and white. Hot enough that I burned my arm just from getting too close with the door open.
I separated 2 bricks with the poker just to see how much they were glowing, and yes, they were glowing solid. The angle iron behind the front air tube MELTED and needs to be replaced. I have seen the top of the stove glow when the fire is burning hard and the blower is turned off. I am unable to stay in front of the stove when the blower is on and the fire is burning full tilt. The blower has doubled the amount of heat we get from this little stove. It is a draft blower from an outdoor wood boiler and it moves some air. It is quite loud too, but it keeps the house warm. The thermometer pegs at about 850° on most burns and gradually drops to about 400-450 for the majority of the burn. Then it slowly drops to about 225 before reloading. Everyone who comes over comments on how warm or hot it is in here and then sees the wood stove as they walk through the kitchen. Most of them walk straight over to it and stand in front until the heat forces them away. The second thing they notice is the thermometer on the wall in the living room that tells indoor and outdoor temp and ask if it is right because it is usually reading about 82° inside.
I have wanted to put a barrel stove in here, but the in-laws would probably melt it or get burned real bad. It would probably roast us out anyway. I will leave the barrel stove in the shop.
On a side note I was talking with a friend of mine last night that has an outdoor boiler. He is a bit lazy which leads me to the story. He had some select cutting done on his property in the summer of 2012, a lot of red oak he told me. He had them leave all the tops etc so he could burn them. He said he can't get the red oak to burn for crap, so I asked him how long its been seasoned. He looked at me funny and said he just goes out and cuts some then tries to burn it, figured its been sitting for a year and a half it should be good. I suggested to him it needs to be split and stacked, or at least cut and stacked off the ground for 2-3 years before he should/could burn it. He then told me that someone else just told him the same thingSo thanks to the knowledge I have gained here I was able to give him an informed opinion that will help him. Time will tell if he heeds my advice
I understand and agree but my point was he couldn't get it to burn. I'd think he should at least cut/stack it so it gets some drying as opposed to laying in the woods. Just my .02Outdoor Boiler guys don't care about seasoning. As long as it burns, they really couldn't care less about chimney fires. It just cleans them out.
My comment was to the glowing firebricks. Ain't no way. I have had a stove up to over 1,400 degrees. Twice. And not one glowing firebrick in sight. After it was pulled out and relegated to smoker firebox duty I had this fire in it. No idea of the temp but no glowing firebricks.
The fire shooting out of that stack is the smoke burning. Your chimney is hotter than the box.My comment was to the glowing firebricks. Ain't no way. I have had a stove up to over 1,400 degrees. Twice. And not one glowing firebrick in sight. After it was pulled out and relegated to smoker firebox duty I had this fire in it. No idea of the temp but no glowing firebricks.
It's -20°F here and the house is at 80°. The lopi is running from 800-300 on a full cycle. It was 90° in here a while ago, but we started sweating and had to let the coals burn for a while.
I have been burning oak the same year it is cut, sometimes even the same week and it burns just fine
