jotul model series 8 leaks and smells like smoke.
I have "strong light" tested
re-cemented the top corners (remove old, pack in new)
replaced gaskets for flue outlet, both of them--the flat and the round ones.
High Temp RTV around pipe adapter (it was already a tight fit)
new top gasket
new top gasket for the round hole in top (from previous models that could have top-flue--mine has a plate)
the only way to detect leaks for me is nose--the top-back-center smells slightly smokey.
Is there a better way to find leaks?
is there a secret to gasketing? this stove has many very thin rope and flat gaskets. I have used thicker ones but they compress down fine. I was very careful about getting them perfect and not stretched at all. every one I have replaced is exactly centered with an equal amount of gasket showing all around and tightly butted.
One time, I pulled the lid and there was trace soot on the stove behind the top. I figured the gasket leaked there where it butted together. so I cut a couple inches out and put in a new piece with tighter butt joints and it WAS BETTER. thinking I had found the leak, I replace the whole top gasket. but now it seems to smell again. I played a similar game with the big hole in the top--now it has a new fat gasket with lots of compression. the lid just sits on these stoves, the holes for the screws were never drilled and tapped. I am tempted to tap them M-6 and add a couple screws but I am not sure it will make much difference. inspection of top gasket shows the corner cement making a smooth indent--i dressed up some casting roughness so the whole top should mate perfectly with the new gasket.
I think I need a leak detector or something...
The only gaskets left are on catalyst cover, ash pan, glass and door. so far, my thinking was that ash pan is too low and door/glass has no smell so I think it is OK. inspection of cat cover gasket did not show any sign of leak (no trace of soot or discoloration, etc).
ANY EXPERTS OF LEAK FINDING OUT THERE?
I AM READY TO SELL IT AND BUY A NEWER ONE (NO CAT) THAT IS SIMPLER AND HAS FEWER GASKETS (THIS JOTUL HAS 8 THAT I KNOW OF. AND THEY ARE STRANGE SIZES/CONFIGURATIONS. PLUS, THERE IS THE STUPID HOLE IN THE FRONT FOR THE BYPASS ROD(I AM WILLING TO ACCEPT THAT LEAK)
i have the minimum reasonable chimney length and am at 5000 ft msl so i have precious little draft to spare. Perhaps any leaks that would be trivial (door, glass, ash pan, etc) are too much for my limited draft install and allows the inside pressure to get high enough to leak somewhere that normally would not be a concern?
any ideas would be appreciated...
ms
new top gasket
ms
