I have both 16 year old JD and 5 year old ZT Cub....Have to say they are both good mechines I give the Jd the higher edge. To me it's the engine that matters both have the Kawaski 22 hp...great engine.
md
md
I'd love to see photos of that spreader mounted to a lawn tractor. That thing is made for a CUT which is not what the OP is looking to buy.
I've got an HD version Cub Cadet that will be 7 years young this spring. I've had no problems with it other than one of the belt tension springs on the deck that's broken once or twice over the years.
I like the Kohler motor the Cubs come with. I love the twist off oil filter, side mounted. I think the JD's may get the same motorl? I've been pleased with Cub Cadet. I'll probably buy one again the next time. If you're going to buy a big box tractor (John Deer, Cub Cadet, Craftsmam, Toro, etc) they are all going to be about the same quality in my opinion. MTD builds them all overseas. If you want something US made with a little more quality you're going to spend a lot more than $1,500 if you want a new one.
When I replace this one, I want a mower with hydraulics. 4wd would also be nice. We have a hilly property.
I think they even make a backhoe for that little thing!
It doesn't take much of a stump to stop a much larger tractor. The owner in this photo apparently failed Physics 101.
That narrows the field down quite a bit. Only 2 manufacturers make 4WD garden tractors with hydraulics. Deere (X700 series) and Simplicity (Legacy XL).
If you can do without the hydraulics, and are just looking to cut grass for the most part (not plow/till the garden, push heavy snow, no loader work, etc) then take a look at Husqvarna's Swedish Riders. They are supposed to be billy goats on slopes thanks to the AWD. Much easier on turf compared to a 4WD garden tractor too.
http://www.husqvarna.com/us/products/riders/r-322t-awd/
Honda doesn't anymore?
We used to have one at work, had a 15ish hp diesel motor, 4x4, power steering, pto, etc. Had a 4ish foot belly mower on it and it worked great.
Yup. But a little big to mow a lawn if you have any tight areas you want to use it on. They don't manuever as well as the X700 series and are more suited for Loader and 3 pt hitch work than being a giant mower.
The X700 has a killer tight turning radius. 25 inches???
Almost impossible to believe.
Of course, the $10k starting price puts it WAY out of reach for the OP, looking for a $1500 tractor.
I bet he's thinking he should set it back down and bury that post hole digger in the ground![]()
1984 JD 425's
Maybe a '94? First 425's were rolled out in 1993 I believe.
It's Begreen that's out for the billy goat mower (rather than the OP) and me thinks his budget might be a tad over $1500 when he gets to that point.
X7 series machines are the kind that get purchased, run for 40+ years and handed down to the kids. Also the kind of machine I wouldn't hesitate to buy with 1000+ hours on it (given that it has been taken care of) for half price.
Ya, didn't mean to barge in on the OP's needs. I certainly expect a full hydraulics mower to cost a lot more, especially if diesel equipped and optioned out.
I see a tractor pull coming up.
I do have a bare ring of dirt around some of them by the end of the season.
That's pretty standard for any ZTR. Doesn't bother me...less trimming.
ZTR can't compare to a 4wd machine. A lightweight ZTR is about as terrible on hills as you can get. A big heavy one is pretty dang good as long as you can keep the nose pointed up hill slightly. As soon as you point the nose downhill there's no turning back....you can't back up and you can't turn back uphill without spinning the @$$ end around (which has a certain pucker factor on steep hills).
Something that really helped mine out was filling the drive drives with liquid. I cut my neighbors property as well and their back yard is almost all a slope. First time I did it when the grass was damp I had to go get the tractor to pull it out of the woods, slide right down at not exactly a slow speed.
Got used to it though, at work we mow the tops of our underground igloos (store bombs, ammo, etc) and they are probably at 45-50* and up down. It takes a pretty skilled operator to be able to sort of control the wheelie or slide without getting hurt or breaking the equipment! Spin out going up hill and you just pull a 180 and run it back down. Do it fast enough and it doesn't stay off camber long enough to roll it over.
