BeGreen said:The Mansfield has an 18" side clearance to combustibles. It's hard to tell from the pictures, but it does look like only about 8-10 inches to the closest wood in the hoop.
Did you mean NFPA clearance to combustibles for unrated stoves is 36 inches?
As I recollect, there are two clearances - one is the clearance to fixed stuff like walls, which is the 18" you mention, the other is the clearance to "anything else" that might be combustible, such as furniture, drapes, firewood, small children, pets, etc.. That is 36" regardless of the stove, listed or not... I think the theory is that such things are likely to be easier to ignite and more flammable than a wall because of their materials and potentially better air circulation around them - also that they would be more easily moved further away from the stove...
For things that will be kept around for an extended period I tend to agree with the 36" number, but I'm less worried about my firewood pyrolizing - pyrolysis is a relatively slow process, my firewood will be going in the stove long before it has much chance to be affected by pyrolysis - however I'd still want to keep it at least the minimum wall clearance away.
Gooserider
