??? Insulated pex lines inside the black corrugated pipe...what everyone uses to move hot water from boilers to air handlers/heat exchangers in another building...
If you dont have Thermopex or similar, that uses closed cell foam inside a solid casing (not corrugated), you most likely have a wrapped pex product that is losing serious heat to the ground.
