I have a different then normal setup. Went out the window instead of the roof. There is a 5.2 degree down angle to the pipe here so rain stays outside. Smoke is leaking out of the damper. I had it running at 600 for 45 minutes and still had no change in draft.
The damper sleeve goes about an inch below the inside roof of the stove.
I have not finished the stove piping outside, it is just sitting open at this time.
Almost forgot, this picture was taken as she was cooling off.
Ps I just installed this and honestly have near no idea what I am doing. I thought "get it hot enough and the draft would take care of the smoke." Maybe the down angle on the pipe is messing that up? Maybe the insert going so far into the stove is messing it up? Maybe I just need to finish putting the outside pipe together? Any thoughts before I smoke myself out! Lol
![16955691417238213109086379655928.jpg 16955691417238213109086379655928.jpg](https://www.hearth.com/talk/data/attachments/315/315774-9b68ed3d44711cefbeec7c7ce25ed73e.jpg)
![16955690958089209687801508270768.jpg 16955690958089209687801508270768.jpg](https://www.hearth.com/talk/data/attachments/315/315773-e649401b4c063721e77efcbd8129101f.jpg)
